Anybody figure out the best way to reduce the body roll?
I was reading the posts this weekend and really didn't come up with a good answer. I drive my tC rather agressivly but when it comes to corners there is a lot of body roll and the rear end seems to want to get lose. So what should I do to (other then not drive agressivly
) to lessen the effects?
the hotchkis sway bars are awesome. i had the trd rear bar and that was really good, but the hotchkis are on a diff level. i don't even have the rear one set on the stiffest setting and it's amazing already. i didnt really think the strut tower bar did much, or at least, i can't really feel a difference. weapon r is also coming out with a rear strut tower bar, so maybe that with the front bar could help a little.
The hotchkis front/rear sway set are awsome. I drove around with just the rear on for a couple weeks, and it was much better then stock, but felt unbalanced up front. Now with the front on, both set to the stiffest setting, I feel much flatter around corners. My buddy noticed it as well and he does not ride in my car much.
Originally Posted by JasonH
Larger anti-sway bars will reduce body roll. I didn't know this was a mystery.
Originally Posted by Series_1.0
my plans are trd shocks and springs with hotchkis sways..i hear the trd shocks reduce body roll dramatically
Can you use the TRD shocks by themselves with stock springs?
you can use trd shocks with stock springs just fine but i dont think its worth it. i think trd shocks are only 5% more dampening force then stock. you should invest in some koni sport shocks. they can go really stiff and have a lifetime warrenty if you doing drop it more then 1.5 inches
Damn I made a post here yesterday but apparently it never went through...
Body roll should by minimized by the springs and struts first, not a sway bar. The sway bars compliment the spring/strut setup, they shouldn't be the primary defense against body roll.
My suggestion is either Progress C1s or Tein SS coilovers and leaving them set high for a clost to stock ride height. The stiffened spring rate will greatly help, and you still have room to make it stiffer later by upgrading the bars if that isn't enough. That's the correct way to do it, but good luck to whatever path you choose!
-Joe
-Joe
Many European tuners subscribe to the "soft springs/struts, stiff sways" philosophy (relatively soft, not luxo-cruiser soft.) The idea being, if you stiffen the springs and struts too much, the wheels will have a tendency to lose contact with the road, but in turns, where you need to control, the sway bars come in to play.
I believe that a tC with stock springs and struts and Hotchkis sways would handle better than a tC with stiffer springs and struts with stock sways.
Needless to say, I'll stand by my current arguement. Sway bars do help your handling drastically, but not as much as a real coilover system could. If your suspension is so stiff that your tires are coming off the ground then adjust the damper rates and keep it planted. Proper tuning (including spring rates, damper setings, camber, toe, and sway bar stiffness) will allow for a ride that handles extermely well, and balanced.
I guess I could elaborate more in case I didn't clear up what I said enough. Feel free to ask what you're wondering.
