anyone know where to find camber links for tc's??? HELP
i know hotchkis makes rear links but i need front links... if anyone has any info i would love to have it, any brand any think i just need to find some. got some tenabe springs dropping it 2 to 21/2 inches so i gotta find a kit... thanks
kai
kai
Re: anyone know where to find camber links for tc's??? HELP
kai
kai
Tai
CorSport
IMO you should look into a camber kit. You can get away without having it installed but you will go through tires faster and your suspension will not be tuned to its full capability. What you should do is get a intial camber reading to determine if you need a kit or not. If your car is lowered more than about an inch I would recommend it. I am not sure what the o.e specs are for camber on a tc but most manufactures is close to zero. Again you don't have to have one but you will wear tires and you wont be getting the full capabilities out of your suspension.. Ingalls makes the "fast cams" and is releasing a rear arm soon for the tc.. I will pm you when the rear arm becomes available. Feel free to pm me with any ?'s and I can help you out...
I forgot to mention.. DO YOUR RESEARCH for compitent performance alignment shops in your area before you go buying stuff. What happens if you take it to people that do o.e. alignments is that they put in factory specs to do that alignment. Well when you lower a car the geometry of the suspension changes as do the specs. SO basically the o.e. specs get thrown out the window..Check the regional forums and ask what is in your area!
VCUBoy714
Scion tC 1G ICE & Interior
01-05-2015 08:46 PM
TheTripleC
01-04-2015 06:46 PM
kleecker
01-02-2015 08:09 PM
