Bigger rotors?
I don't know a lot about bigger brake kits but is it possible to get slightly bigger cross drilled rotors with stock calipers? I want to get rims soon and i think stock tiny rotors look horrible on bigger wheels without a big brake kit, but i just want to get the rotors for now.
So just want to know if its possible.
what do you mean it doesnt help?
you asked for larger then stock rotors w/o goin intoa bbk
powerslot plus rotors are bigger then stock and include brackets to move the stock caliper out
Does powerslot sell drilled and slotted rotors? Any other companies sell rotors kits like powerslot?
Originally Posted by jdubb123
Originally Posted by KrazyAznScion
just get slotted, no need for drilled
i personally dont think so.. but yea.. just get slotted, if drilled as well you run a higher risk of warp/cracking.. its just me cuz i prefer performance over looks..
contact brembo, im pretty sure you can custom zinc coated rotors without upgrading calipers... just make calls and im pretty sure you're bound to find one that will make one and fit, i've seen willwoods, rotoras, and vise versa on stock wheels...
Is there a certain diameter rotor or something that it has to be to kit the stock caliper?
Cuse if i knew what size i would have to do i can search around a little easier
the only one/two "bigger" rotors i've seen fit stock wheels with kit is the powerslot ( size already figured to fit stock wheel) and a baller slot pattern on a rotora/wilwood rotor if you want a cool lookin slot pattern... google/search it..
Thanks for the help
Oh and i should just stick with the same dimensions as the powerslot rotors to ensure a good fitment right
Thanks for the help
im pretty sure i never said anything about rotors larger than powerslots...
he's askin for bigger rotors than stock without goin bbk, and he wants one that is coated to look bronze or what not.. so i recommended to make calls and look for some other larger than stock rotors...
never said anything bout goi bigger than powerslot..
Yeah im also looking not to spend 500 bucks on custom rotors though lol Then i would just get a whole kit.
https://www.scionlife.com/forums/viewtopic.php?t=245771
The outer rim where the slots are are silver now...its black in that picture because it was before I bedded the brakes in.
SouthernCaliTC
Sep 15, 2015 01:58 AM
