Brakes, Finally. DONE.
Old Jul 7, 2008 | 09:30 PM
ack154's Avatar
Default Brakes, Finally. DONE.
After about 61k miles... I've finally ordered new brakes.
Just placed (literally) my order with Dezod for a set of 4 Dezod blank rotors and Axxis Ultimates all around.
I wanted more bite from the pads for autox and it was between these and a few others. I may have actually ordered the Dezod pads, but he said they were backordered anyway. I went with Dezod rotors b/c I just want a blank. Don't need any slotted or drilled things for my use. And the Dezods have a painted hub to hopefully cut down on potential rust down the road.
Will definitely be posting info when the swap gets done. Not sure when it'll be yet though.
Old Jul 8, 2008 | 12:14 AM
NurSpec's Avatar
congrats on the upgrade!
make sure to bed them in properly. NEED PICS
Old Jul 8, 2008 | 01:28 AM
ack154's Avatar
Thanks. Will definitely have pics up.
Old Jul 8, 2008 | 03:00 AM
tCeeder's Avatar
you might end up wanting to switch the pads....i HATED the axxis pads that came with my Stoptech Stage 2 kit. they are dusty as hell so i went with EBC Redstuff. for autox you'd be better off with Yellowstuff.
Old Jul 8, 2008 | 11:20 AM
ack154's Avatar
I've actually heard the EBC pads are all really dusty. I can put up with a little dust for the better bite... but I'll just have to see exactly how much once they get installed. I'll keep the yellowstuff in mind though. Thanks!
Old Jul 8, 2008 | 11:40 AM
davedavetC's Avatar
wont it look like stock? and whats the benefit of getting the "blank" rotors over another set of stock rotors?
Old Jul 8, 2008 | 11:47 AM
2fast4you's Avatar
Team ScionTific
They are less expensive than stock. Last I checked, it was $50+ per stock rotor.
Old Jul 8, 2008 | 11:50 AM
CDogbert's Avatar
Just to make sure, you got OEM size rotors, correct?
Old Jul 8, 2008 | 12:15 PM
ack154's Avatar
Yes, they're OEM size and will look stock. No need to go bigger at this point. I'm not worried about the look, just want some more bite (hence the pads) and figured I'd replace the rotors right along with them since they're original as well.
Autozone has front rotors for $35 each and rear for $30 each... but I'd rather get the Dezods partially b/c they have the painted center and partially b/c I'd trust them more than a Duralast rotor.
Napa, on the other hand, has fronts for $52 each and rears for $35, so Dezod is cheaper there.
I didn't bother calling Toyota on them. Partly b/c of the painted hubs on Dezod's and partly b/c I'm lazy.
Old Jul 8, 2008 | 03:43 PM
davedavetC's Avatar
gotcha
Old Jul 8, 2008 | 06:00 PM
CDogbert's Avatar
Coo'. I was just making sure because you were worried about staying in STS with the crank pulley; rotor size change will kick you out.
Old Jul 8, 2008 | 06:07 PM
ack154's Avatar
Ya, I figured. I actually didn't even consider going larger though. Too much of a budget concern.
Old Jul 9, 2008 | 03:03 AM
davedavetC's Avatar
i found the powerslot plus rotors (rear anyways) for under 300 shipped with pads and lines
Old Jul 9, 2008 | 11:24 PM
ack154's Avatar
Part 1:
Ordered Monday from Dezod, received today.
Rotors had to be shipped from the manufacturer or source or wherever they come from and should be here early next week.
Old Jul 9, 2008 | 11:36 PM
jsingh's Avatar
OhioScions
nice...
watching!!
Old Jul 10, 2008 | 05:19 PM
paul_dezod's Avatar
Scionetics
KAD
I HATED the Redstuff on my old car. SUPER noisy, super dusty and just overall too high of a friction coefficient on them. Ultimates are a good choice.
Old Jul 10, 2008 | 06:16 PM
CDogbert's Avatar
Watching for how these do. I'm patiently awaiting StopTech pulling it's head out of it's ___ and sending them to me.
Old Jul 10, 2008 | 06:20 PM
ack154's Avatar
I'm hoping to get them installed either some time mid-next week if I have the time after work or next Saturday before the AutoX event on Sunday.
Old Jul 10, 2008 | 06:31 PM
SanFranTC's Avatar
I would recommend Hawp pads before the EBCs. I have used both the HPS and the HP+. If you want some serious grip and don't mind dusting or the shorter lifespan of the rotors get the +.
I switched from a Wilwood big brake kit on my last civic to factory rotors, stainless lines, Hawk HPS and better fluid and couldn't tell much of a difference. The reason I switched is because the Wilwoods for the EP3 civic didn't have dust seals so after a few thousand miles they started making some serios noise from the crap that had made its way to the pistons.
Old Jul 10, 2008 | 06:32 PM
ack154's Avatar
^ Stainless lines are another consideration. But at $150 a set... I don't know yet.
