C Pillar Bar
megan racing has a c pillar bar... cheap.. but it will be right across at the rear pass. heads.. so i wouldnt do it..
i heard you can use the integra c pillar bar and install it a little bit far back.. but i dont care.. i will go with the ingalls rear brace.....
better handling and lot of ppl said aliminates some roof noise.. and thats why i wanted to go with the c pillar.. so i will take the ingalls
i dont know about the harness... but yeah.. if you have the megan c pillar bar then its really bad to sit in the rear........i never tried it.. but i heard from everyone who has this bar.... this why i wouldnt get it..
if you want a c-pillar bar just got a 94-01 integra c-pillar bar. won't have any problems with people seating in the back seats since you will use a different hole on your pillar to mount the bar.
^ He said it hooks in a diff spot. Does it hook up lower or higher? Further back or closer to the front seats?
For 59.99 for the integra Id just get the one for 10 dollars more thats made for the tC.
It doesn't attach to the seatbelt mount, it attaches to one of the holes further back. I'd be concerned with the mounting point flexing or bending. Plus, with the seat belt mounted megan bar, there is a threaded hole. I don't know how the Integra one would mount.
there are other holes that are already threaded you just need to buy a bolt that would fit. there was a thread with pics here somewhere. if you find it you will know exactly what im talking about. if you are concerend about people sitting in your back seat, this is the only solution to this.
i'll save you some time. here is the link. goodluck https://www.scionlife.com/forums/viewtopic.php?t=83673
if you get the one made for tc that fkin bar would be across the seatbelt line... it means your rear passengers would hit it with hes head..........................................
so if you one to get the c pillar bar without any problem you need to tget the integra one... and that one will be just as the same like the other one.. how do i know?? because TCPete has that bar for months/years now without any problem!!!!!!!!!!!!!!!!!!!!!!!!!!!!
i would get it but im gonna go with the ingall 4 point rear brace................
Originally Posted by Dondirtyj
point D is where the c pillar bar made for the tc would go. as you can see it will bother anyone who sits in the back seat.
