Check out my new rotors! 56K Don't even try!
Old Apr 8, 2006 | 11:25 PM
johnnyTCblaze's Avatar
Default Check out my new rotors! 56K Don't even try!
For your viewing pleasure, newly installed rotors! 'Cuz you have to match your socks wit your shoes!
And big ups to rock blocker for the Red Reverse Light Overlay.
Old Apr 9, 2006 | 12:17 AM
chrischoi's Avatar
very nice. from where? and how much>
Old Apr 9, 2006 | 02:48 AM
BubbaNoy's Avatar
looks like ebay slotted and crossdrill rotors...
Old Apr 9, 2006 | 05:29 AM
ScionizedRS's Avatar
hey where u get did you get your grillz from, they are tight
Old Apr 9, 2006 | 05:31 AM
L4rry_B1rd's Avatar
look like the ebay grillz too
Old Apr 9, 2006 | 05:32 AM
d_gage's Avatar
word x2, oh and did you change the pads?
Old Apr 9, 2006 | 05:34 AM
L4rry_B1rd's Avatar
http://cgi.ebay.com/ebaymotors/Scion...spagenameZWDVW
most likely from here or the other 5 people selling these on ebay.
Old Apr 9, 2006 | 11:32 AM
tikbhoy's Avatar
i hope those are not knockoffs. ill rather change the pads than be cheap on the rotors.
looks good tho but....
Old Apr 9, 2006 | 02:26 PM
scrap's Avatar
I 'm doing my brakes at the end of the month. I am going with EBC sport rotors and EBC redstuff brake pads. I'll post pics when I change them out. I think that is a RS1 grille not a ebay one.
Old Apr 9, 2006 | 08:04 PM
L4rry_B1rd's Avatar
might be an rs1 but you can get the ebay grillz for $80 and they look just like the rs1's.
http://cgi.ebay.com/ebaymotors/2005-...spagenameZWDVW
paint it black and you have your rs1 grille
Old Apr 9, 2006 | 09:57 PM
coppermine18's Avatar
Sorry about the dirty wheels in this cause of the weather but I just put my new rotos in a few days ago as well.
Old Apr 13, 2006 | 05:11 AM
solorider's Avatar
Looks nice 'cept you got them rotors on backwards, at least if they're drilled and slotted to match the veins.
Old Apr 13, 2006 | 06:03 AM
J_Leon's Avatar
Did you use any special tools to remove the old rotors?
Old Apr 13, 2006 | 08:22 AM
That is the right front -it is on right they were all labled anyway.
No - pull off the wheel, pull the 2 caliper bolts that hold the entire assembly on, life off the brake and pull off the rotor.
The rear you have to make sure you have the e-brake off though because that portion of the brake is a drum.
Old Apr 13, 2006 | 08:41 PM
solorider's Avatar
Sorry, I was refering to the original poster's car, not yours. I should have been more clear about that.
Old Apr 13, 2006 | 08:47 PM
The_Instigator's Avatar
The tC rotors have straight vanes so the slotting/drilling pattern really makes no difference. The direction the slots lean really has no impact on performance one way or another.
Old Apr 16, 2006 | 10:40 PM
Typhoon's Avatar
^so iam guessing the only way to significantly imprive breaking is a bbk?
Old Apr 17, 2006 | 12:09 AM
No there is a huge braking improvement because of the rotor temp decrease when you get on them.
He just means that because of how the rotors are it doesn't matter which direction the slots/holes are.
Old Apr 17, 2006 | 02:46 AM
Actually a slotted rotor has less heat capacity due less material on the rotor to absorb heat. It is not significant enought to cause noticeable differences but there are the performance benefits of increased bite and pad cleaning.
The best way to improve braking performance is with tires. The tires limit the maximum deceleration achievable so until your brakes cannot lock up your tires, you are giving up stopping distances. Street tires will only go so far (right around 1 G) and race tires arent suitable for street use.
Upgraded pads are the best bang for your buck when it comes to improved bite and response, followed by SS lines to improve pedal feel and response. Rotors are more of an appearance upgrade but do add some bite although not significant on a street car.
Where a big brake kit can help is with tweaking the brake bias to get the ideal balance which can reduce stopping distances all other things being equal, although most factory systems offer minor balance improvement. As it turns out, most BBK manufactureres do not do the testing to optimize balance and some even end massively overbiasing the front end of the car which not only increases stopping distances (sometims 30-40 feet), but also can make for a soft pedal with long travel and issues or complete malfunction of ABS and chassis control systems. This usually occurs when a standard caliper with fixed piston sizings are applied to multiple applications which is suprisingly common in the industry. Sadly, many customers spend thousands of dollars on a BBK, olny to find out thier car brakes worse with performance tires than a stock car on stock tires. These issues become glaringly obvious in performance tests like the recent RSX Challenge:
http://www.stoptech.com/company_info...hallenge.shtml
Old Apr 17, 2006 | 11:07 PM
Typhoon's Avatar
^hm thanks a lot very educational. Performance pads wear down rotors faster though right? So what about the stoptech stage 2 brakes upgrade
