Clunking Noise? HELP!!!
Old Oct 20, 2006 | 09:43 PM
stl_tc_king's Avatar
Default Clunking Noise? HELP!!!
When I go over bumps the back end of my car makes loud clunking noises. It is not the hatch, it is coming from under the car.
I lifted it up yesterday and checked all the bolts (all tight), I checked to make sure the wheels were on snug (all good), and I checked to see if anything was hitting anything else, but no luck!!
The noise seems to be loudest when im driving at speeds between 20-30mph over bumpy roads. I have an idea what it may be, but I want to hear other opinions.
As far as aftermarket suspension parts go, I have Hotchkis springs and Hotchkis front/ rear anti-sways.
HELP!!!
Old Oct 20, 2006 | 10:38 PM
paul34's Avatar
If I am thinking of the noise you are thinking of, this happens if I go over bumps too quickly. Just slow down and you'll be ok.
Old Oct 21, 2006 | 12:41 AM
BLUEMEANIE's Avatar
Team Hamster
its prolly your end link ... I've had it happen before on my camry. They're grease packed bushings that pivot, if one tears the grease will dry up and it will clunk around.
PM me if you want to come by and I can take a look at it or I can do it at the Lou Fusz show on sunday if I make it by.
...I can swap it out for you when you get a replacement, I have all the proper tools at my house.
Old Oct 23, 2006 | 05:53 PM
BOXMAN's Avatar
Mine did the same thing. Make sure your rear sway isnt shiffted to one side more than the other side. If it is the endlink will rub.
Old Oct 23, 2006 | 08:03 PM
B1uEsC1uEs's Avatar
happened to me too, I just tightend the endlink and it was all gone.
Old Oct 23, 2006 | 09:19 PM
tan_Cao's Avatar
check to make sure that your rear shocks are on tight as well. I drove over a bump and the nuts came right off, I'm not sure how the hell they managed to do that, but I ripped apart the back and shocks weren't bolted down.
Old Oct 24, 2006 | 01:46 PM
thanks for the suggestions guys. If it is the end links, would it be covered under warranty?
bluemeanie- i appreciate the offer and i'll be certain to let you know if i need any help.
Old Oct 24, 2006 | 02:30 PM
BOXMAN's Avatar
^^^ No it wont be covered by warranty in most cases. They will say the sway bar is 300%+ stiffer than the stock oem one and now the sway bars have became the issue not the crappy weak stock end links.
Old Oct 24, 2006 | 05:00 PM
tcsti's Avatar
wow, i have the same noise, only up front. that makes me want to check out the whole car now.
Old Oct 24, 2006 | 05:18 PM
Beantowntc's Avatar
I have the same noise....I think its my trd sway but not sure. Anyone know how much the endlinks go for??
Old Oct 24, 2006 | 05:24 PM
BOXMAN's Avatar
^^^^I think in the 25-40 buck range per side. ^^^^
Old Oct 26, 2006 | 04:22 AM
Thanks for all your help everyone.
The problem was solved by tightening all of the nuts that are associated with the rear sway. Specifically in my case, the driver's side end link was pretty loose. Once everything was tightened back up, the car is MUCH more quiet.
You know, it really is great when you can simply post a problem that you have and you are answered with possible solutions.
I sincerely thank all of you who posted in my thread.
Old Oct 26, 2006 | 04:32 AM
Spect2K3's Avatar
Glad you got yours fixed. I've tried everything to the extent that i'm going to the dealer on saturday for them to take a look while i'm still under warranty. I hate having them touch my car!
Old Oct 27, 2006 | 10:03 PM
d_gage's Avatar
i have a loud noise also coming from my car and i'm running tein coilovers. hopefully this is only and endlink noise. thanks for the information guys!
Old Oct 29, 2006 | 01:21 AM
Spect2K3's Avatar
Just wondering, what exactly are the endlinks? Does anyone maybe have a picture (or ideally a DIY) of what to tighten? Any info would be appreciated b/c this is driving me crazy. The dealer told me I blew the rear struts (even though i'm only on TRDs), but there is something up front too...
EDIT: I suppose that if I were to find my way to tightening the endlinks, I would need to know the torque settings if anyone happens to have em
Old Oct 29, 2006 | 02:42 AM
Spect2K3's Avatar
any info for a beginner on the placements of those endlinks?
Old Oct 29, 2006 | 02:44 PM
Spect2K3's Avatar
bump, this is driving me crazy guys!
Old Oct 29, 2006 | 03:31 PM
d_gage's Avatar
well i just got in from the garage going over the rear suspension, everything was tight so now i have no idea where this clunk is coming from
Old Oct 30, 2006 | 01:58 PM
Try tightening the bolts that attach to the ends of the sway bar. This is where my biggest problem was.
Old Oct 30, 2006 | 02:15 PM
Spect2K3's Avatar
any idea of torque specs by chance?
i'm also not really sure how to access the ends, do you have to take the wheels off?
