Coilovers or Springs? wat brand/kind?
ok guys/girls. i am new to this car stuff so bare with me pls
i have read through previous post but still cannot decide on what to get.
I want my car to be lower, but not to low to where i am scraping on dips/bumps. I also dont want it to low because i will eventually be getting some type of lip kit on my car.
i think coilovers would be nice because i can adjust the height. but i have read that people say it is to bouncy. is there a certain kind that would fit my standards as far as me being a daily driver?
as u can see i am really confused, lol, and can use some help.
also, if i were to buy coilovers or springs, wat other future upgrade will be needed, and how soon.
thanx guys.
i really appreciate it
thanx guys.
Originally Posted by melvynray
im talking about springs. he may be talking about coilovers...
i suggest springs for a daily driver
I have H&R coilovers installed on my tC (here's my review: https://www.scionlife.com/forums/vie...light=coilover ). I find the ride to be slightly stiffer than the TRD shocks/springs, but it is far from bouncy. They don't have adjustable dampening because they don't need it; H&R got it right the first time by properly matching the dampers (shocks/struts) with the proper spring rates. They cost a few hundred dollars more than other coilovers with the same features, but they come with a level of quality not found in many of the more expensive models.
I hope this helped.
if you got the money, i would recommend the Tein SS-P's along with the EDFC (this way YOU can control how stiff or smooth your car rides). My buddy has them and the ride is great and the EDFC adjusts the rate so it can be maxed out for track use (which it seems you might not partake in) and can lower it for a more comfy ride.
Save yourself money and buy the TRD lowering springs. It will work perfectly for you. The drop isn't too low yet it wont look like its stock. So once you get your lip kit, scraping will be the last you youo'll be worrying about. Don't get coil overs, you'll never need the adjustibility of it. TRD Spring is the way to go especially for you.
But if you feel like the ride isn't that smooth or that its not right, you can always get a set of TRD shocks to match it up for a better ride.
Coilovers shouldn't be bouncy, merely very firm compared to stock. If they are bouncy it is because they have the dampening adjusted to harshly.
Tein makes a very good coilover, the Basic, thst are height adjustable, but have no dampening adjustability. If you want a more tunable ride the SS system (Super Street) offers 16 levels of dampener adjustement to suit most driving styles and road conditions.
If you just want springs Tein has H.Techs and S.Techs. The Hs are a softer (still firmer and lower than stock, and the S.Techs are a fairly hard spring.
See details here:
Springs
Coil Overs
See details here:
Springs
Coil Overs
wow!!! thanx for the input guys.
i didnt realize that the coilovers were that expensive
i wont be able to purchase anything until close to the end of the year, but i'll only have about 5 bills to spend. is there anything that i can get to suit me for under 5 bills?
And stay far, far away if someone tries to sell you coilovers for $500.
Like 2fast4you, I have H&R coilovers. I don't know how they are compared to other brands, but I can tell you they've exceeded my expectation. A comfortable ride was priority for me and that's just what I got. They are not bouncy either so that's a plus.
But if your budget is under 5, then springs are the way to go!
Don't forget to get an alignment after you have it lowered.
i was thinkin bout goin wit trd's at first, but i wont a slightly lower drop. do u think the tein H would be a problem for me?
i heard that u have to by struts, but not for another 10-20k miles. is this tru?
also, lol, would the tein H be to low if i plan to add a lip kit?
One thing to keep in mind is that you are modifying your car, and if you can't cover the cost of any possible complications you shouldn't do it. If you're not ready to invest in a new set of struts, play it safe and go with TRD.
i see ur point. how much do trd struts cost + installation, cause i dunno how to install.
coo. and if i got the tein H springs, future trd struts wont be a prob for it. and is there anything else that i would need?
and will these springs affect any chance of me being able to get a lip kit, or will i be good?
thanx again
thanx again
thanx again
thanx again
As far as the lip kit goes, you should be OK if you exercise some caution. However, I have a stock body and a 1.75" drop in front and I barely clear standard size parking blocks... be careful when parking!!
thanx again
thanx again
barely goin over the parking block? wow!
how is it going over speed bumps/railroad tracks/dips, etc
