Dan Gardner Custom Sway Bar is now available thru Dezod Motorsports
Old Mar 1, 2010 | 09:27 PM
  #121
pinoyFMtC's Avatar
Originally Posted by paul_dezod
21 sold guys! Only 29 left.
Ballpark on when they'll be shipped out?
Old Mar 2, 2010 | 11:49 AM
  #122
mechaBORED's Avatar
Thanks for the update paul. PLEASE keep updating us on how many of these are left! I'll probably pick one up too, but I can't do it till my next paycheck or the one after that.
Old Mar 2, 2010 | 01:15 PM
  #123
paul_dezod's Avatar
Scionetics
KAD
I emailed Jeff at Progress yesterday morning ironically enough. I will post once I have info
Old Mar 2, 2010 | 01:20 PM
  #124
engifineer's Avatar
I already received mine.
:D Yeah... just kidding.
Old Mar 2, 2010 | 01:47 PM
  #125
GrnBrownies's Avatar
you had me going for a second
Old Mar 2, 2010 | 04:25 PM
  #126
Flipside87's Avatar
just put in my order
Old Mar 2, 2010 | 07:16 PM
  #127
Domo's Avatar
Paul, I believe someone said Dan Gardner will be offering other products as well. Can you tell give us a sneak glance of any upcoming products or what we are looking at?
Old Mar 2, 2010 | 09:15 PM
  #128
paul_dezod's Avatar
Scionetics
KAD
The sway bar (this)
harder poly mounts
coilovers
camber plates
some other stuff is still down the pipeline too.
Old Mar 2, 2010 | 09:42 PM
  #129
engifineer's Avatar
keep me updated on the camber plates Paul. Working up ideas on a custom coilover setup, which would need camber plates unless I can work it out to re-use the top mounts from the SS-P's.
Will probably be a while on my end, but it will be good to be in the loop on the plates.
Old Mar 2, 2010 | 11:02 PM
  #130
adg016's Avatar
Guys,
Paul is correct on the items listed...though we'd also like to see what kind of take rate there might be on the suspension and subframe bushings. Here's an example of how the DG-Spec stuff would be different.
--Motor Mounts and Suspension and Subframe Bushings
Much harder than the standard stuff. My durometer-spec allows for minimal deflection.
--Camber Plates: Same basic design but offered with more adjustment and big 3/4 inch sphericals. We would build adapters for each customer on a case by case basis depending on your shocks. True, perfect fit each and every time.
--Coilovers: Two sets of different valving depending on how hardcore you need. Both well exceed the street kit. We hand select spring rates.
--Long wheel stud racing kit: 20 in the kit, plus the ability to add open lugs in either 17 or 19 mm heads.
That's a start guys.
Old Mar 3, 2010 | 02:19 AM
  #131
davedavetC's Avatar
ball joints too?
Old Mar 3, 2010 | 03:07 AM
  #132
engifineer's Avatar
Some custom spindles would be nice... so the car could be lowered without affecting geometry as much :D But, that is an expensive run part for the few people that would probably actually buy it.... not to mention it would throw me into "A pile and a half of money worth of mods to still get beat by a frankenstein 300 WHP stripped to 1800 lbs miata" class at our autox events....
But anyways, are you thinking camber/caster plates or just camber?
Old Mar 3, 2010 | 04:23 AM
  #133
adg016's Avatar
ABSOLUTELY will have both camber AND caster. Sorry should have mentioned that.
Old Mar 3, 2010 | 04:27 AM
  #134
RoboCop's Avatar
Can you just sell a DG spec tC? Haha
Old Mar 3, 2010 | 06:37 AM
  #135
adg016's Avatar
Funny you should mention that. There's been talk of doing it...either through our team, or through a dealership.
Old Mar 3, 2010 | 01:51 PM
  #136
paul_dezod's Avatar
Scionetics
KAD
That'd be sweet! Fully equipped with a Dezod turbo too.
Old Mar 3, 2010 | 10:58 PM
  #137
Domo's Avatar
It would be crazy if Dan did Time Attack. Since Ptuning no longer is running the street or modified class, Dan could be the one to break records. With a Dezod turbo of course.
Old Mar 4, 2010 | 01:18 AM
  #138
Cheddaville's Avatar
bought my sway in full on saturday night.
waiting for that big box at my door!
Old Mar 4, 2010 | 03:09 AM
  #139
Need4Bass05's Avatar
I think just about everyone is anxious for that box to show up.
Old Mar 4, 2010 | 03:41 AM
  #140
RoboCop's Avatar
Progress needs to respond to Paul so Paul can update us. I want this bar!
