Dc Strut tow bar
Old Nov 20, 2006 | 10:52 PM
ryan9800's Avatar
Default Dc Strut tow bar
I live in seattle and when it rain it rains. When I'am at a stop and get into it an accelerate somtimes i will get wheel hope and it seems the engine will tap on the Dc tower bar. Does anyone else get this?
I bought a engine dampenr to hopfully cure this problem....
Old Nov 21, 2006 | 02:49 AM
sddykstr's Avatar
Use the engine dampner, should solve your problems. Or you could just not hit the throttle so hard in the rain.
Old Nov 21, 2006 | 03:05 AM
Tcguy85's Avatar
the engine damper will help quite a bit, plus look sweet under your hood! i like mine, put it on 12mm instead of the 14mm it'll come set at. i set mine on 12mm and it doesn't seem to make anymore noise than it did on the 13mm i tried first. it really makes launching the car nice, and helps shifing... even under normal driving. just don't let the extra noise bother you. you'll get used to it.
Old Nov 21, 2006 | 03:48 PM
ryan9800's Avatar
I'm sure i will figure out what you are talking about with the 12mm and the 14mm when i get it. I hope it works.
Old Nov 21, 2006 | 04:53 PM
tikbhoy's Avatar
Default Re: Dc Strut tow bar
thats because you barely have any traction! its a wet road and your times are jumping in n out. try to moderate your gas pedal off the line.
the engine will never tap on your DC unless you lift it up enough by then your car should be totalled.
engine dampers are just band aid to the problem, your best solution if your still using the stock tires is "performance Tires"
Old Nov 21, 2006 | 05:07 PM
ryan9800's Avatar
My engine does tap on the tower bar. Do you have a DC tower bar? Its closer then normal. Yes tiers may help but i still need somthing suporting the engine more when spinning the tiers accures. If i get new tiers and the wheels still will spin and the engine still will tap then i have not fixed anything.
Old Nov 21, 2006 | 06:05 PM
tikbhoy's Avatar
its really hard to srew up on installing the strut bar.
you need to take pix of what part is hitting it because i highly doubt it.
yes i do have one.
normally people who upgrade wheels n tires spend too much money on rims they want while getting the cheapes tires.
also your last sentence is so wrong in many ways/// my 2cents
laforze
12
Feb 16, 2016 12:50 AM
maximthegreat
Jan 19, 2016 02:31 PM
carid
Scion tC 2G Aero & Exterior
Sep 1, 2015 09:08 PM
Bmfxtreme
Aug 18, 2015 01:25 AM
goatbelly
Jul 12, 2015 10:13 AM
