does anyones progress rear sway bar make alot of noise?
like creaks.. when ur going up a driveway or over a speedbump.. or turning fast.
my sway bar sounds like a talk show when i do stuff like that.,.
i jacked up the car and checked everything I COULD.. but everything seems fine.
It probably just needs to be lubed... hehe... lube.
That is, the bushings need some lube. Mine does it too. Hopefully you have greaseable bushings/brackets on it that have the little nipple on them to attach a grease gun to.
First check if it is properly lubed. If it is, try reinstalling it with the car on ramps (so that the suspension is under load).
Sometimes if you tighten those parts without the suspension loaded they can squeek.
TheTripleC
Jan 4, 2015 06:46 PM
yamahamx117
Scion xD Suspension & Handling
Dec 25, 2014 01:54 PM
PTUNING
Dec 11, 2014 08:09 PM
