View Poll Results: Replace 2 struts I jacked up with 2 new stock struts for 150 or buy new trd struts for 460?
Stock...save the cash.
50.00%
TRD
50.00%
Voters: 4. You may not vote on this poll
excessive fluid around shock base?
Old Dec 29, 2006 | 04:38 AM
Andrew1782's Avatar
Default excessive fluid around shock base?
I have noticed that I was getting an odd noise over every little bump coming from the right rear of my car.
I am lowered on TRD with stock struts.
A friend of mine pushed up and down on the back hatch to replicate the noise while I tried to find where it was coming from.
After concluding it was coming from the shock itself, I put her on jacks and took off the wheel. It looks like a bit of fluid buildup around the base of the coils at the bottom of the shock. Is this normal after 9k miles or do you guys think that this shok could be blown?
The niose it would make when we pushed on the hatch was almost like an empty belching noise.
What are your thoughts?
Old Dec 29, 2006 | 11:19 AM
fsan619's Avatar
does sound like the shock is blown. the only area that that fluid could be coming from is the inside of the shock. Might want to see if the dealer will exchange the shock itself if you are running on TRD's.
Old Dec 29, 2006 | 02:31 PM
Andrew1782's Avatar
Well here is the thing. During the install the back shock was scuffed on the rod. I thought maybe the shock travel wouldn't go down to the oint where the scuff is but it looks like that was an optimistic point of view.
The empty belching sound.....does that coincide with a blown shock also?
Thanks for your help!
Old Dec 29, 2006 | 02:43 PM
peteyd's Avatar
blown shock! trust me i blew my front ones being lowerd on h-techs with otu upgraded struts.(tC only has struts..no shocks fyi)
Old Dec 29, 2006 | 03:03 PM
sciontc_mich's Avatar
sounds like the scuff on the rod, caused a unsmooth surface on the rod which wore on the seals of the struts, causing it to leak fluid. So yes sounds like that's why the shock/strut has failed. Time to get a new one.
Old Dec 29, 2006 | 03:54 PM
Andrew1782's Avatar
Yeah I know they are all struts. The odd thing is originally I was getting a rattle over bumps and thought hmmm maybe the hatch rattle?? Then I couldn't find anything loose. Looked at the shock and messed around a bit and I think the rattle over the bumps was from the shock too? Everything is tight but if it is mostly out of fluid would it cause it to rattle and be noisy too?
Old Dec 29, 2006 | 04:51 PM
yes it could be causing rattles, as the only thing holding the car up on that side is the spring! So yes, I would expect it to be making noise. it would sound more like a shudder than a high pitched rattle, i think..
Old Dec 29, 2006 | 04:53 PM
Andrew1782's Avatar
^^^ shudder is what it sounds like yes.
Old Dec 29, 2006 | 07:00 PM
yup.. typical of a shock/strut failing. time to buy a new one unless you like the bouncing on the one rear side ;)
Old Dec 29, 2006 | 07:01 PM
Andrew1782's Avatar
Actually its not bouncing at all......yet lol
Old Dec 29, 2006 | 07:02 PM
well lucky you! yeah guess it's time to get a whole new TRD set.. always a good excuse
Old Dec 29, 2006 | 07:04 PM
Andrew1782's Avatar
^^^ Yeah......dangit.......LMFAO. Ahhh well. I was just speaking with my girlfriend about whetherto buy TRD or replace with stock...her response?
"I think you should get the TRD that's what you really want right? So if it costs more but it's what you will end up getting anyway you should."
Always good to know your woman understands!
Old Dec 29, 2006 | 07:07 PM
yes.. sort of like those mastercard commercials.. and then there is your quote from your girlfriend. the response? PRICELESS
seems that the TRD shocks are better equipped to put up with the demands of a lowered suspension anyway! might as well do it now and be done with the replacement. Just make sure they do the alignment correctly after they're replaced.
Old Dec 29, 2006 | 07:16 PM
Andrew1782's Avatar
yeah and lets hope I dont jack up the rod this time.....
Old Dec 29, 2006 | 07:22 PM
you have learned much andrew-son (using japanese voice) you shall be victorious next time (bows to you).. lol yeah come on-don't screw it up (insert sarcasm here)
make sure to get the alignment checked after you do that.. oh and keep us posted on how it goes. might want to use new original bolts for the lower part of the front strut. That can affect the front camber settings (moves from front to back to adjust front camber), hence of the recommendation of the alignment
Old Dec 29, 2006 | 07:41 PM
Andrew1782's Avatar
^^^ explain more on the bolt issue? You think I should get new bolts??
Old Dec 30, 2006 | 12:33 AM
there are two bolts at the base of the front struts and depending on hitting potholes/bumps, i've seen where those can get bent ever so slightly (need x-ray to measure it, so naked eye can't see it). Which can affect the camber settings. Plus you can pull the steering knuckle area in and out, which will adjust the camber in the front. That's why an alignment rack is needed to measure this after the front struts are installed.
If you get new bolts (have to specifiy the original bolts, because a different combination of other bolts will adjust the camber) they are only like a couple bucks for each. Just was being proactive so that don't reuse the old ones and then wonder why the camber isn't perfect. Hope that makes sense.
Old Dec 30, 2006 | 01:21 AM
Andrew1782's Avatar
^^^ hmmm. The dealer said those bolts are about 12 bucks a pop. I only have 9k on my car do you really think those are needed?
Old Dec 30, 2006 | 02:14 AM
well maybe not.. guess you can get the car up on the alignment rack and see if the camber is good.. if not, then you'd need the bolts.. there's a good reason
goatbelly
Jul 12, 2015 10:13 AM
Munch
49
Feb 1, 2004 11:58 PM
scionaraxb
33
Jan 30, 2004 08:33 PM
avus
Dec 3, 2003 12:45 AM
swtbabiboi4u
Oct 13, 2003 04:38 PM
