front camber bolt help
ok im looking for more negative camber to fit some wheels in the front i have some questions
do i need 1 or to bolts on each side to max negative camber??
which bolts max out the most eibach ingalls or spc?
Check out H&R sports there camber bolts are +/- 3 degrees and can be reused. Most others are one time use (check the details) there spendy but quality. You can use two sets per corner but won't see double
Check out each manufacturers web site for accurate specs.
http://www.hrsprings.com/products/triple-c/
http://www.hrsprings.com/application/
SkillFreeJake
Scion tC 2G Aero & Exterior
07-27-2015 12:34 AM
TheTripleC
01-04-2015 06:46 PM
kleecker
01-02-2015 08:09 PM
