Function and Form Front Sway Bar Endlinks rattle
Old Jan 27, 2013 | 01:23 AM
coquitc's Avatar
Question Function and Form Front Sway Bar Endlinks rattle
Just install them and they make a knocking sound every bump i get.i adjust them to 8 inches.does anyone knows how low needs to be adjust? I'm on s-tech and tokicos with stock sway bar.
Thanks.
Old Jan 27, 2013 | 11:00 AM
Roller_Toaster's Avatar
Did you tighten them when the car was on the ground or in the air? They should be tightened when there is a load on the suspension, not when it's up in the air.
I had a similar issue not long ago.
An easy fix is to jack the car up and put the front wheels on ramps, so you can reach the endlinks to tighten them while the suspension is loaded.
Old Jan 27, 2013 | 01:00 PM
coquitc's Avatar
I did it with the car in the air.going to try that.thanks.do you or anybody knows how low or high I need to adjust it?
JPuehl
Jan 10, 2015 01:01 AM
kleecker
Jan 9, 2015 02:26 PM
757_BRDFLY
Jan 9, 2015 12:29 PM
TheTripleC
Jan 4, 2015 06:46 PM
yamahamx117
Scion xD Suspension & Handling
Dec 25, 2014 01:54 PM
