General questions on TRD shock install after reading forums
Old Apr 12, 2006 | 05:38 PM
coppermine18's Avatar
Default General questions on TRD shock install after reading forums
1. I already have TRD springs will it be even lower with the TRD Shocks?
2. I have 18's should I cut the bump stop? - Just front or front and rear?
3. Should you use loctite on the strut bolts *read this somewhere did not think it was necessary*
4. Anyone run into any install difficulties along the way?
Old Apr 12, 2006 | 06:12 PM
The_Instigator's Avatar
Height will not change, but the ride will firm up and the car will stay flatter while cornering. You do not have to cut your bump stops at all (I didnt and have no issues). No loctite is required anyhwere..just a basic remove and re-install. If you didnt need a spring compressor to install the TRD srpings on the stock shocks, you will need one to get them on the TRD shocks. The shock shaft will want to pull back into the shock body making much more spring compression required to get them installed.
Old Apr 12, 2006 | 06:48 PM
How long for install time?
Old Apr 12, 2006 | 06:51 PM
hunterUnknown's Avatar
I don't want to say much because it took us 11 hours, due to some "difficulties" but ideally, it SHOULD be some 4-5 hours if you work quickly and efficiently. Pretty much if you've done it before. It'll be like changing your springs, but onto a different shock. Same process.
Totally worth it, by the way.
Old Apr 12, 2006 | 06:56 PM
ScionBandit's Avatar
sIcKsCiOnS
DelMarVa
Scion Tuners
your gonna have to cut the bump stops, the ride height really wont change
it did when i had my s-techs and TRD shocks, dropped it slightly
install is fairly easy, if you have the tools
Old Apr 12, 2006 | 07:01 PM
I am proficient with any type of automotive work - however I've just never found myself changin springs or shocks ever just brakes etc.
I think all my rotors took about 1.5 hours with pad change in the front.
The first front took the longest because I had to overcome the small technical difficulties on tools.
Old Apr 12, 2006 | 07:13 PM
Should take the same time as a spring install. Did mine in under 3 hours.
Old Apr 12, 2006 | 08:22 PM
why would you have to cut the bump stops? I didn't.
Old Apr 12, 2006 | 08:28 PM
sIcKsCiOnS
DelMarVa
Scion Tuners
when i got mine, er had mine back in the day
TRD told me to cut the bump stops
Old Apr 12, 2006 | 08:37 PM
I didnt cut mine and see no reason to cut them. Theres is no harshness over large bumps, but cutting the stops is very easy and wont cause problems either. Make your own decision on this one...it really wont make a difference either way
Old Apr 12, 2006 | 08:39 PM
sIcKsCiOnS
DelMarVa
Scion Tuners
i agree, im just going with what i got in the box from TRD
Old Apr 12, 2006 | 09:20 PM
Well - I found out mine were cut when the springs were put on. I had the springs put on with the car and the tech is a friend of mine. I asked him if I should cut them he said 'I already cut them in half'.
I had them put em' in so I could put them in the financing, and Trav knows what he's doing atleast he builds some awsome tuners.
Old Apr 13, 2006 | 12:08 PM
sciontc313's Avatar
what is bump stop?? just wonderin
Old Apr 13, 2006 | 08:30 PM
It sits on top of the strut around the shaft is the stopping point where you are fully compressed and the car comes down on it.
ALSO - Did anyone need an alignment after installing these? I already have the TRD springs on...
Old Apr 13, 2006 | 08:34 PM
sIcKsCiOnS
DelMarVa
Scion Tuners
haven't aligned it, gone through 4 different suspension set-ups
rides fine, only thing off is the camber
posiden
Mar 22, 2015 03:03 AM
TheTripleC
Jan 4, 2015 06:46 PM
minter66
Dec 15, 2014 01:45 PM
swtbabiboi4u
Oct 13, 2003 04:38 PM
swtbabiboi4u
Oct 10, 2003 01:40 AM
