Ground control coilover sleeves?
Old May 22, 2007 | 12:49 PM
Blacklistcustomz's Avatar
Default Ground control coilover sleeves?
Anyone have input on the Ground control coilover sleeves? I like how you can adjust the height of your ride like a coilover, without spending a thousand dollars... but does anyone know how good these are quality wise, ride wise? And say i lowered them 1.6 inches all around... do i need new struts?
Old May 23, 2007 | 12:27 PM
ack154's Avatar
I don't think many people have them (if any). If you do consider them, I don't think I'd use them with OEM shocks/struts... maybe TRD ones or something... but at that point, you might as well look into some nicer ones anyways.
Old May 26, 2007 | 05:39 PM
PhilDis's Avatar
My friend has a SR20 240sx with them, and ive never been so scared in the twisties. He also has them paired with some koni yellows, the car STICKS to the ground like its on rails.
Old May 31, 2007 | 01:13 PM
BLUEMEANIE's Avatar
Team Hamster
I had sleeves on an old corolla for a whileway back in the day. With good struts they're not a bad option for the money conscious so long as you stick with a company that makes them specifically for the car you're buying them for. GC uses correctly matched rate Eibach springs.
Old Apr 24, 2009 | 09:42 AM
ALaS's Avatar
why is it scary?
Old May 13, 2009 | 04:01 AM
KiKaZ-tC's Avatar
Default Re: Ground control coilover sleeves?
I've used them before with stock shocks... with 340 front/ 440 rear and it wasn't really too bad... except the fronts would come popping up and make a banging noise when you go over a crevice on the freeway. With the GCs you can always choose custom lower spring rates to work well with the stock shocks.
I would not recommend this to anyone that wants to lower their car lower than 1.6" in the front. The only way you could lower it more would be to cut the stock housing spring perch.
BlackKnight
Sep 15, 2015 06:42 AM
danielv
Aug 26, 2015 07:14 PM
scionlife
371
Jun 2, 2015 11:00 PM
TheTripleC
Jan 4, 2015 06:46 PM
