help with body roll
I have an 07 tc with some mods but still have to much body roll any ideas on how to fix this????I have TRD springs/struts/and front strutbrace.... I was thinking about a TRD rear swaybar & rear strut brace i dont want to loose any warrenty so in not sure if i have to stay with trd or what??I would also like to know if TRD makes a front swaybar for my 07 if any knows ???please let me know..THANKS!!!!!
go with the hotchkis sway bars(front and rear), and a rear strut tower brace. I have the ingalls 4-point brace(very nice, but you can't put the foam tray things back in.
*the dealership can't void the warranty just because you put on a non-Toyota front/rear sway bar or rear strut brace .
my suspension set up:
Hotchkis Front Strut Brace
Hotchkis Front/Rear Sway Bars
Ingalls Rear 4-point Brace
TRD Shocks/Struts
Hotchkis Lowering Springs
= me very happy in the corners
TRD Shocks/Struts
Team Sushi
I have no spring/strut modifications, and I've almost completely eliminated body roll with the trd rear sway. I've done springs on other cars, and I can tell you that the TRD rear sway has made a bigger impact than those other modifications on body roll. IMO, I like to keep as much independence on the front as possible (for road imperfections), and with the very neutral handling with the rear away, I want to avoid any other modifications that might upset that balance.
Hotchkis makes a front and rear sway...
And you won't void your warranty. Use the search button and you'll find all the answers you could ever want.
Team Sushi
True race cars use ZERO sway bars. They eliminate sway by using extremely stiff suspension. Sway bars are a band aid and allow you to keep softer springs for road use... F1 cars have virtually zero suspension travel, but if an F1 car hit a pot hole at 80MPH it would probably lose control, which is why having some suspension travel for road use is important.
Team Sushi
And the problem with going overboard with sway bars is that under extreme loads, it will cause the inside wheel to lift off the ground... Which will not make a devastating impact (as most of the load is carried by the outside tires), but it WILL decrease traction.
the trd rear sway is all you need for the street. if you autocross you might feel the need for more. i have the trd rear sway, hotchkis springs, and the dc sports fr strut bar and i love the handling of my tc. very little roll. my car will oversteer a little bit sometimes instead of understeering.
Team Sushi
My driving style? I tend to enter turns a bit too hot at times (driver error). A bit of understeer helps to pull the car around safely and allows me to exit full throttle in a nice gentle slide. With just the TRD, I am absolutely in love with the balance. I've actually driven a tC with the hotchkis set, but it wasn't my cup of tea. But it all comes down to preference. But like I said, roll bars are really a band aid.
you want less body roll the absolute best solution is front and rear anti-sway bars. i had the trd rear sway, and the dc strut tower brace, then i put on the hotchkis front and rear and it made the car feel so solid i noticed it as soon as i sat down in it.
doesn't have to be hotchkis, could be like progessive or any other good brand that makes front and rear sets.
Team Sushi
^ agreed. I wouldn't even think of arguing with that. My point was more so about balance. But yes, the trd alone will still leave some slop in the front.
I actually just had some Hotchkis sways installed on my car. I still have stock springs and struts (for now) but already I notice a massive improvement over stock when taking exit ramps, turning hard corners, etc. Id say go with Hotchkis just because thats what I put in but choose a front and rear set that fits your needs & budget.
SouthernCaliTC
Sep 15, 2015 01:58 AM
