hotchkis front and rear sway bars
Old Feb 2, 2005 | 05:51 AM
helloimerwin's Avatar
Default hotchkis front and rear sway bars
does anyone know if the hotchikis front sway bar can be used with the TRD rear sway?
Old Feb 2, 2005 | 01:02 PM
Tamago's Avatar
sure, why couldn't it?
Old Feb 2, 2005 | 02:35 PM
thanks, i'll probably try it out if i get impatient waiting for TRD to come out w/ the front....haha
Old Feb 2, 2005 | 03:29 PM
Tamago's Avatar
you can mix and match most suspension components, keeping common sense in mind.. i plan on selling my rear sway (hotchkis) once i build a stiffer replacement.
Old Feb 2, 2005 | 04:18 PM
ty6's Avatar
ty6
Go for it. I just installed Hotchkis sways, both front and rear, and I like them a lot. I tried the harder setting in the front first, but I didn't like it, so I switched to the softer setting. With the soft setting I feel I get more tire contact. The hard setting feels good at first, but I noticed that it was too stiff and I was getting more lean towards the outer edge of the tire.
Thought this might help.
Old Feb 2, 2005 | 05:47 PM
Does anyone know the diameter difference between hotchkis rear vs. TRD rear sway?
Old Feb 3, 2005 | 02:46 AM
ty6's Avatar
ty6
Hotchkis rear is 27mm, not sure what TRD is though. I tried to look it up, but couldn't find it.
Sorry,
Old Feb 3, 2005 | 02:51 AM
thanks!
Old Feb 3, 2005 | 03:03 AM
ty6's Avatar
ty6
yep...and that's compared to stock at, if I remember correctly, 23mm. Someone may come along and correct me on that.
Old Feb 5, 2005 | 04:21 PM
asthmatic's Avatar
How difficult is it to readjust the sways stiffness? Do you have to reinstall the whole thing or does it just take acouple of minutes?
Old Feb 7, 2005 | 03:55 PM
Wide_tC's Avatar
To adjust the stiffness you just undo the endlink and move it. You do not need to remove the bar.
Old Feb 7, 2005 | 03:57 PM
Wide_tC's Avatar
Old Feb 14, 2005 | 06:49 AM
yesti's Avatar
ty6 trd rear is 24mm. stock is 21/22mm (5spd/auto)
Old Feb 14, 2005 | 05:09 PM
ty6's Avatar
ty6
Thank you yesti!
Old Feb 15, 2005 | 05:34 AM
jrv2000's Avatar
I got my hotchkis bars installed about 4 days ago, and they are making a lot of rubbing noise. Is this normal? The guy who installed it didn't use both tubes of grease that were provided, could it be that more grease is needed? Please respond, so I know if I need to get this fixed or not.
John
Old Feb 15, 2005 | 03:30 PM
Wide_tC's Avatar
John
John,
If the rubbing noise is more of a squeek then it is probably the bushings. Also because you have to drop the front subframe make sure that everything is tight. Hope this helps.
Old Feb 15, 2005 | 08:26 PM
hahaitzskippy's Avatar
John
John,
dont you have to grease up the bushings a little? so the squealing wont be there?
Old Feb 15, 2005 | 11:21 PM
Wide_tC's Avatar
John
John,
That is correct if not enough grease or no grease at all was used the bushings will squeek. That is a common problem with any product that uses polyurethane bushings.
Old Feb 16, 2005 | 05:52 AM
jrv2000's Avatar
Thanks, I went back to the shop today, and they just took the grease gun to the bushings. It only makes a little noise when im going over speed bumps, but otherwise they are completely quiet. great product that I would recommend to everyone. I can take corners at 50 now!! One problem is that the bolts provided with the kit are little bit too small. The shop got ones just like it just a little bit longer.
Thanks,
John
Old Feb 18, 2005 | 07:11 PM
JasonH's Avatar
Default Re: hotchkis front and rear sway bars
You could do that, but you probably don't want to. Here's why:
The TRD rear bar is made to work with the stock front bar to give the tC more neutral handling. From the factory, the car understeers. The addition of the TRD rear bar brings the tC closer to neutral (no oversteer, no understeer.)
The Hotchkis front bar is made to be used with the Hotchkis rear bar. They are both much stiffer than stock (and stiffer than the TRD rear bar,) and are tuned to give the tC neutral handling when used as a pair.
If you put the Hotchkis front bar and TRD rear bar on the tC it will corner flatter than stock, but it will tend to understeer. Ideally, you want the car neutral, or even a little towards oversteer since the forward weight bias makes the car tend to understeer regardless of suspension setup.
Either go with the Hotchkis set or the stock front/TRD rear setup.
