Hotchkis rear sway only?!
Old Jun 19, 2008 | 06:36 PM
flint_08's Avatar
Default Hotchkis rear sway only?!
I know that it is not recommended, hence the reason it comes in a set, but how many people are running the rear sway?
If I used it on the middle setting rather than the stiffest setting, would I be alright?
I use the car as a daily driver, but also autoX as well. I plan to do coilovers later this summer, likely KSports or TEIN Basics.
Any input?
Old Jun 19, 2008 | 06:54 PM
engifineer's Avatar
Even on the softest setting, I wouldnt do it. For autox, it may not be too bad (until you upset the cars balance in a slalom.. then you will be backward). But cars oversteer easier on "normal" corners. So on the street you run more risk of spinning the car. If you just want a rear sway, run the TRD. It is about the best balance with the stock front.
Why wouldnt you just install the front and rear hotchkis sways?
Old Jun 19, 2008 | 08:24 PM
tcCALI's Avatar
^ seriously.
Old Jun 19, 2008 | 08:35 PM
enjoithis's Avatar
dont do it, just install both... anyone that does do it doesnt know what theyre doing
*my appologies to anyone who installed only the rear
Old Jun 20, 2008 | 04:33 AM
flint_08's Avatar
^ seriously.
Rear sway install is about $45 ... front and rear sway install is $400. In other words more than the product costs itself. Thats why.
Old Jun 20, 2008 | 06:25 AM
tcCALI's Avatar
thats way to much money for install of both.
Old Jun 20, 2008 | 10:40 AM
flint_08's Avatar
I have called three different places now and that is standard. The average bench time for both is roughly 3.5 - 4 hours of labor. Which in Long Island is roughly $400. From what I here that is somewhat normal. Thats the reason why I was trying to find someone on here that would do it for a few bucks and a case of beer.
Old Jun 20, 2008 | 01:46 PM
engifineer's Avatar
Yeah, find someone that can do it for you. You have to lower the subframe a bit in the front to get that one changed, which is why it takes longer.
Old Jun 23, 2008 | 02:07 AM
silverstreaktc's Avatar
3.5-4 hours? thats a little too long to install the sways
Old Jun 24, 2008 | 03:35 PM
jiggadomino's Avatar
rear you can do yourself
the front one is the one that requires some professional help
doing the rear only doesnt sound bad, you should test it out on a few corners first though
hopefully you dont oversteer too much
airmankevin1
Feb 14, 2018 01:23 PM
RY_TC07
Jul 18, 2017 05:18 PM
Erager09
Sep 26, 2016 03:11 PM
TheTripleC
Jan 4, 2015 06:46 PM
