Hotchkis Sway Bar Instructions
Old Jun 15, 2005 | 05:35 PM
Wide_tC's Avatar
Default Hotchkis Sway Bar Instructions
For all of you interested in the Hotchkis Sway Bars here is the installation instructions.
http://www.hotchkistuning.com/bin/in...ions/22425.pdf
Old Jun 15, 2005 | 05:42 PM
Mr_Meaty's Avatar
Did you change them to mention that the slotted brackets go in the back and the brackets with the hole go in the front?
Old Jun 15, 2005 | 06:04 PM
Wide_tC's Avatar
Yes we did. We are always trying to improve our instructions and products.
Old Jun 15, 2005 | 08:48 PM
yamaha16bw's Avatar
anything on how to adjust the steering wheel? I did everything by the book but my wheel isnt centered. It doesnt pull at all just its just offset to the right.
Old Jun 15, 2005 | 08:59 PM
Mr_Meaty's Avatar
If you get under your car and take out those 4 really tight bolts again, it should disconnecte the wheels from the steering whell. Then, just push the wheels straight and then make sure you steering wheel is straight. Then put the 4 bolts back in and you should be good to go.
Old Jun 15, 2005 | 11:17 PM
Marshall's Avatar
Thank you so much Hotchkis for updating the instructions
Gawd this is a... beeyatch... of an install.. but it's soooo worth it
Old Jun 16, 2005 | 02:21 AM
boostedscion's Avatar
yea thanks for helping us out.. I saved the instructions to prepare for future install
Old Jun 16, 2005 | 02:24 AM
yamaha16bw's Avatar
See everyone says this. There were way more then 4 TIGHT bolts! Which ones do you mean? Cradle or steering rack?
Old Jun 16, 2005 | 03:03 AM
Mr_Meaty's Avatar
Step 7. The 4 that connect the steering rack to the cradle.
Old Jun 19, 2005 | 04:51 PM
yamaha16bw's Avatar
^^^ Thanks for clearing that up for me!! Do I just need to loosen them to get it to move? I would think that it would be hard to just loosen and move the whole rack. SHould I keep the wheels on you think or take them off to do this?
Thanks again for the help!
Old Jun 25, 2005 | 03:52 PM
asthmatic's Avatar
what are we suppose to torque the rear sway bar at?
Old Jun 25, 2005 | 04:25 PM
Mr_Meaty's Avatar
What do you mean? You mean how hard do we torque the bolts holding the end links of the sway bars? I didn't use a torque wrench for them, so I just did it as hard as I could.
Old Jun 26, 2005 | 04:14 AM
Marshall's Avatar
Can Hotchkis offer any tips for all of us that still has our stearing wheel off slightly?
Old Jun 26, 2005 | 05:41 AM
Mr_Meaty's Avatar
I thought we answered this already? Put your car up on jack stands and leave the wheels on. Undo those 4 bolts that hold the steering rack tight. Then, make sure you'r tires are straight, and center your steering wheel. Then make sure your tires are still straight and tighten those 4 bolts back on. Just give it a try while your waiting for conformation from Hotchkis.
In the mean time, since no one with the sways seems to be reading my other thread have any of you started getting the roof creek since installing the sways? I didnt' get it before, but now I do turning over bumps, like pulling out of my driveway.
Old Jun 26, 2005 | 06:21 AM
yamaha16bw's Avatar
I get it! Sounds like a bolt has come loose. I was going to check it out tomorrow. I also have a sub I just install which could be part of the problem.
Old Jun 26, 2005 | 12:55 PM
Mr_Meaty's Avatar
I KNEW IT! But you didnt' have it before? I guess it could be a bolt got loose, and the added body ridgity may have something to do with it. I've been driving quite differently since I've installed my bars
Old Jun 26, 2005 | 03:22 PM
Marshall's Avatar
My moonroof made the same popping noises going in and out of my drive way before my sway bars were installed.
Loosening up the steering cradle bolts and aligning the steering wheel straight does not correct it. When my steering wheel is straight the car still want to go to the right.
Old Jun 26, 2005 | 05:20 PM
CELL's Avatar
wheres my damn stickers
Old Jun 26, 2005 | 08:29 PM
Mr_Meaty's Avatar
Oh, if your car is pulling to one side when you take your hands off the wheel, you have an allignmnet issue, wich may not be caused by anyting you did with the sway bar. The problem I was trying to help with was if you car is driving perfectly straight, but your steering wheel is not centered.
Cell: I got my stickers a few days ago. cut off the "www.hotchkis.net" part and put them on my quarter windows. REPRESENT!
gedster314
Regional - Pacific South
Feb 19, 2021 07:51 PM
rvascion
Nov 12, 2020 03:23 AM
SloTC1
Aug 16, 2018 02:45 PM
babyfac3pn01
Oct 19, 2015 07:24 AM
