hotchkis sway issues...
Old Mar 6, 2006 | 02:48 AM
Neothin's Avatar
Default hotchkis sway issues...
alrighty, stock shocks dropped on s-tech's. I've got a set of hotchkis sways sitting in the garage. i've seen people rub with stock shocks on a hotchkis drop which is a bit less than the tein springs. Because of this, I'm expecting some rubbing.
Now, i've read somewhere that 03 camry endlinks can be substituted and this would alleviate the rubbing problems. Is this true? What kind of problems can be had from using camry endlinks? I read somewhere about the camry being 10mm something and the tC being 12mm something.
anyone's input would be appreciated.
just thought that I'd ask.... Is the rubbing going to cause any actual problems or is it a noise nuisance issue that wont really affect anything?
Old Mar 6, 2006 | 05:00 AM
zer0's Avatar
I believe the rubbing issue had to do with the Coilover system not the S-Techs...
You'll be fine!
Old Mar 10, 2006 | 12:20 AM
unlimited77's Avatar
So i was planning on getting this set of front and rear bars, and then in the future going with tien ss set. Would it rub then?
Old Mar 10, 2006 | 12:59 AM
ack154's Avatar
I don't think there has been any rubbing with the Hotchkis springs... most of the reports were with some sort of coilover system.
Old Mar 10, 2006 | 01:14 AM
Yanki01's Avatar
<-- has hotchkis and no rubbin
Old Mar 10, 2006 | 03:55 AM
So they will rub with tien ss, and do the endlinks come on backwards, or swapped?
thanks
Old Mar 10, 2006 | 04:16 AM
IndigoTC's Avatar
MN Scions
i have tein s techs and hotchkis rear sway bar with no problems. i am going to buy new endlinks because they seem kind of small.
Old Mar 11, 2006 | 03:41 AM
Syndicated_Death's Avatar
what is meant by "rubbing" forgive my ignorance
Old Mar 11, 2006 | 03:52 AM
ack154's Avatar
The sway bar is rubbing on another part of the suspension in hard cornering or other situations. Basically, it shouldn't be touching anything else.
Old Mar 27, 2006 | 06:31 PM
jaydub's Avatar
I have hotchkis springs, stock struts, and hotchkis f & r sways. My front sway DOES rub, and it has since day one. It has been reinstalled twice by different technicians at the Scion dealership, to no avail. Now the bushings are squeaking. It's about a week away from coming off and heading for the garbage.
Old Mar 27, 2006 | 06:40 PM
yamaha16bw's Avatar
Same problem^^^ for me. I ditched mine awhile ago.
Old Mar 27, 2006 | 09:37 PM
stl_tc_king's Avatar
I have hotchkis springs, stock struts, and hotchkis f & r sways and have NO rubbing, or noises, or anything else that is problematic. Sorry to hear you guys are having problems. Mine have been on for about a month and I do quite a lot of driving.
I LOVE my new suspension set-up and have nothing but praise for hotchkis!
Old Mar 28, 2006 | 03:12 PM
jaydub's Avatar
give it time, mine have been on for about six months now.
Old Mar 28, 2006 | 03:32 PM
xbrixbrix's Avatar
Apparently Hotchkis had updated their sways with welded on washers in the front and rear like the stock sways, so that the bar dosnt slide to either side. Mine slid to the cars left and bent the sway bar from hitting the suspension arm so much. I had it on for about 2 months before I couldnt stand it anymore so I took it off and finally called Hotchkis. They told me about the update and theyre trading mine in for a new one.
Old Mar 28, 2006 | 04:11 PM
jaydub's Avatar
Originally Posted by xbrixbrix
Apparently Hotchkis had updated their sways with welded on washers in the front and rear like the stock sways, so that the bar dosnt slide to either side. Mine slid to the cars left and bent the sway bar from hitting the suspension arm so much. I had it on for about 2 months before I couldnt stand it anymore so I took it off and finally called Hotchkis. They told me about the update they and theyre trading mine in for a new one.
That's good to know, and also quite disheartening since they haven't bothered to contact anyone and let them know.
I won't be going this route again in the future, that's for damn sure.
Old Mar 29, 2006 | 02:37 AM
yamaha16bw's Avatar
yeah I called them more then once on this same issue and I always got the same answer. "NO we are not changing the design on the front sway bar."
gedster314
Regional - Pacific South
Feb 19, 2021 07:51 PM
SloTC1
Aug 16, 2018 02:45 PM
maximthegreat
Jan 19, 2016 02:31 PM
babyfac3pn01
Oct 19, 2015 07:24 AM
Scionxa180
Aug 30, 2015 04:12 PM
