hotchkis sways question
Old Jan 26, 2008 | 10:57 AM
lex990's Avatar
Default hotchkis sways question
aside from getting rid of body roll... do these affect the roughness of the ride very much? or just make your car stay flatter on the road in the corners?
Old Jan 26, 2008 | 02:08 PM
dex's Avatar
dex
stiffening the chassis in any way is gunna make the car ride rougher. i couldnt tell you to what degree though...i didnt put them on until after i had the teins.
Old Jan 26, 2008 | 05:09 PM
lex990's Avatar
i know it will ride a bit rougher but i wanted to know if it was a big difference or just a tad bit... i don't think they would make it as bad as drop springs
can't drop my car but alteast i could stiffin it up a bit
Old Jan 26, 2008 | 05:56 PM
azureloki's Avatar
you mean your keeping stock suspensions except you want to add a sway bar set?
Old Jan 26, 2008 | 07:53 PM
lex990's Avatar
yep
Old Jan 26, 2008 | 07:56 PM
SoleLaced's Avatar
oh. I had the TRD swaybar with stock struts/springs
i actually didnt feel a difference and mine was set on race (stiffer setting).
Hotchkis are a bit thicker but Im sure you wont feel it too much, if anything
EDIT: it also depends on your tolerance.
Old Jan 28, 2008 | 12:38 AM
davedavetC's Avatar
you will notice it big time, i have H&R coilovers, and i installed the H&R sway afterwards and it made it a little more stiff, but when you upgrade the front and the rear it will be a lot stiffer and you will notice a big improvement in handling, and if you think you cant drop your car, maybe you should look into the TRD spring/shock combo, a mild drop but increase in handling (big time), suspension upgrades are one of the most enjoyable upgrades i think makes driving the car a lot more fun. and theres nothing like taking an off ramp faster and smoother then you could stock :D
Old Jan 28, 2008 | 12:47 AM
FreedomOne's Avatar
I'm looking forward to get TRD coil overs later this year. As for strut and sway bars, I don't own them but I believe that you would feel a difference at high speeds. That's just a guess.
Old Jan 28, 2008 | 05:38 AM
kungpaosamuraiii's Avatar
BIG difference. My friend's car on Hotchki's sways only handle better than mine on TRD springs only.
Scionxa180
Mar 13, 2015 04:39 AM
dinkjs
35
Jan 13, 2004 11:55 PM
rodney_ray
9
Dec 31, 2003 04:40 AM
rodney_ray
Dec 23, 2003 08:41 PM
ONEQWICKSCIONXB
Dec 20, 2003 05:44 PM
