how low can you go
under a 2" drop all you need is an alignment (Tein H-Techs, TRD, Skunk2)
2" and over and you will need camber correction (Tein S-Techs, Hotchkis, Dropzone, Zenn and most coilovers)
Also, if you go over a 2" drop...you will eventually need new shocks because the stock shocks will only last so long (there have been people with S-Techs lasting around 30k miles before the shocks needed to be replaced)
haha yeah chris... as soon as my shocks blow, coilovers here i come! but ummm buddhas.. i rock stech's, and with just an alignment, im within factory specs for all suspension related items (caster, camber, toe)
Harrison, i think i remember seeing a rear view pic of your car and your tires were at a negative camber...i might be wrong, it might be someone else. Do you have a pic of the rear view?
yep, tiny bit of camber. within spec though.
a perfect alignment when stock is at negative 56 minutes of camber. there's a range from like 1.5 degrees to 0 degrees to be consdiered within spec
hmmm...not bad, just a tad bit more negative camber than mine on H-Techs...and i've had em for close to 2 years with the same beautiful tires(Nitto 555 series) and still have plenty of tread life left and minimal inside wear on the rear tires. I retract my previous statement about S-Techs
BlingSlade
Oct 19, 2016 12:39 AM
gqdabien
Sep 17, 2015 09:23 PM
