I really need some Help
I recently installed Eibach Pro Kit Springs
TRD Rear Sway
I had 2 new Kumho AST 18in Tires Installed
Alignment was done and everything was within spec
Today driving home from work i noticed this weird thumbing noise coming from the rear of the car. It was hard to produce while driving. It happened at weird times..Once while stopping felt like something was loose. Once while making a turn and going over a slight bump. I can produce it when going up my driveway. It seems like something is loose or rubbing on the sway bar. But I am not sure.
Please help..its killing me not knowing what it is. Click the video below it was taken on my phone might not do any justice.
View My Video
TRD Rear Sway
View My Video
The weird thing is i just test drove it again on the street near my house with a few dips in the road. I hit thos dips going pretty fast and no noises. If the shocks need to be replaced is it bad to drive around with it for awhile...I have no money to replace them at this time
Where are the strut bolts located?
the strut bolts are those 4(or 3 forgot haw many are on tc) bolts on top of the strut in your engine bay. if they are loose then that could making the struts loose which is making noise
if your shocks are blown, you'll notice the car being much lower on the side where the shock is blown. there is very little chance of that happening right after you got your springs in.
Originally Posted by ack154
If your shocks are blown, it would be quite a bit bouncy too.
when my shocks blew out the car didnt go any lower and it had that noise like a loosen bolt but when i opened up everything and took one of my shock out i could press that thing all the way in with my bare hands without any pressure.. but double check the bolts first.. open all bolts one by one and tighten it up.. see if that helps..
