Just installed a rear sway (Thanks Matt)
Old Jan 19, 2008 | 08:47 PM
Guille_Tc's Avatar
1UP Crew
what setting is it on?
Old Jan 19, 2008 | 08:52 PM
tc1stgen's Avatar
The stiffest one
Old Jan 19, 2008 | 11:57 PM
engifineer's Avatar
Originally Posted by tc1stgen
I have just the rear right now. But I also have the Ingall's rear shock brace, strut tie bar, and springs. Next for me suspension wise is gonna either be shocks or a full damper kit. Then I will get the front sway and pretty much be done suspension wise. I want to start working on the exterior now though. I have left the outside stock for the most part and have worked on the engine and suspension. So now that it has a little more *****, I can get wheels lip kit and such. Too much to do and very little money! ;(
There is no front TRD sway. You only need to get a stiffer front bar if you run a much stiffer rear bar. That is why the hotchkis comes in a set. If you got a front hotchkis, for example, and ran it with the trd rear, you would end up pushing (understeering) more than you want, which is one reason you want the trd rear to begin with, to decrease understeer.
If you get a super stiff rear, like the hotchkis, it can make the car oversteer too easily, which is why it comes with a stiffer front bar.
Old Jan 20, 2008 | 12:03 AM
jld's Avatar
jld
oh so THAT's why there's no front TRD sway on trdsparks... I was looking through threads that came up in a 'sway bar' search and it seems like the front sway is harder to install because you have to lower the engine or something.. I think i'll stick to TRD when I get the sway bar! thanks for the info engifineer!
Old Jan 20, 2008 | 01:22 AM
bigwillystyle23's Avatar
yea the trd is def. the way to go. combine that with lowering springs and you got a great upgrade. and if you got the money to get the shocks/struts..do that at the same time you do your springs. itll save you so much trouble in the long run. not to mention making your ride EVEN BETTER
Old Jan 26, 2008 | 12:00 AM
Guille_Tc's Avatar
1UP Crew
TRD Springs and Rear Sway is sitting in the closet. Cant wait till install this Sunday! Will tell u guys how it is the moment i test it out.
Squishface
Sep 15, 2015 06:51 AM
killahXB2
Mar 27, 2015 10:45 AM
757_BRDFLY
Jan 9, 2015 12:29 PM
kdepew
Jan 5, 2015 12:42 AM
TheTripleC
Jan 4, 2015 06:46 PM
