Low dust brake pads?
I washed my car 10 days ago and my wheels are already covered in brake dust. Anyone recommend good low dust brake pads for the tC? front and rear. I used to use Mintex pads on my VW, but it doesnt look like they make a set for tC's. Btw, I went on Kragen.com to check pads and I found 05 tC's, Camry's (4 cyl), and Celica GTS (04) all use the same front brake pads.
some wheel cleaners come with brake dust repel. You might want to try that instead of spending $$$ on the brake pads. As for the brake pads themselves I have no idea but maybe you should try the different material that the brake pads are made of
Two good low dust pads for the tC are the Hawk HPS and Axxis Deluxe Plus. The HPS is a higher performance pad than the Deluxe plus but is also about 3x's the price. Either pad will be an upgrade from the stock pads in terms of performance and reduced dust.
I bought the Hawk HPS's for $79 from TireRack.
But the idea about getting some wheel cleaner with built-in brake dust repellant is a GREAT idea, I'm going to go to Advance Auto Parts this weekend and pick some up. Thx!!
You may want to check to make sure you got the HPS sent to you bcause there is also the Hawk HP+ which is known to be very dusty and quite loud even when bedded in. Check the box to make sure they didnt accidentally send you the wrong pads because those characteristics sound an awful lot like HP+. FYI the HPS come in a purple box while the HP+ come in a black box. Also the HPS pads have the letter "F" in the part number with the HP+ having the letter "N".
I guess I am lucky. Brake dust doesn't show up very well on my Release Series rims. The dust does make the rims look not as shiny, but that is the only way I can tell unless I try to wipe them off with a rag. Then I can see how much dust is actually on them.
i have the hawk hps pads for the front, and the satisfied pro ceramic pads for the rear. neither set is very high dust. don't get me wrong, they do dust, but i don't think they dust nearly as much as the axxis ultimates. those things dust like crazy from the what i've seen on people's cars who have them. also, prestone has this spray crap that is supposed to kinda repel brake dust or something like that. i tried it when i had the stock pads in, and i'm not sure if they really help that much, but they do get wheels cleaner, so whatever. either way, i gotta clean my wheels, so might as well use the stuff that might help prevent brake dust.
George
25
08-31-2004 05:38 PM
kdanie
10
01-25-2004 07:08 PM
