Low Speed Brake Grind noise....Hmm
Old Oct 12, 2007 | 06:55 PM
TeeCizzle's Avatar
Default Low Speed Brake Grind noise....Hmm
OKAY....so...I have the EBC Greenstuff front pads....PowerSlot front rotors...
If I go below 5MPH and press the brake I get a God Awful Grinding noise from the brakes...
that okay?..
Somehting I need to worry about???
Also..I have only had that brake rotor combo for 5 months now...already starting to get a Minimal squeal....is cuz of colder weather????....wasnt sure!
Thanks everyone if u can help!!!
Old Oct 12, 2007 | 08:20 PM
Angry_Celi_Guy's Avatar
did u break them in properly? or did u start stomping on ur brake pedal like everything was good from the start?
Old Oct 12, 2007 | 10:58 PM
TeeCizzle's Avatar
Way back when I installed everything...
I did the 5 or 6 times of going up to about 40MPH then break....
then another 5 or 6 times around 55MPH....
They dont make a sound at Reg. speeds and braking...
ONLY when I am going under 5MPH then add pressure to the brake...Like going through a Drive-Thru...etc..
Old Nov 4, 2007 | 08:37 PM
fparklin's Avatar
i think ur rotars are uneven, or wasnt resurfaced properlly... well thats what my mechanic said about my stock rotors..
i had the same problem... slow speed brake causing a continuous scraping noise..
evolving_machine
Oct 21, 2023 01:16 PM
scionlife
371
Jun 2, 2015 11:00 PM
toyotaisme
Jan 10, 2015 10:24 PM
