Motor Mounts
Old Apr 11, 2008 | 07:11 PM
Schuller's Avatar
Default Motor Mounts
I got these from Nurspec. Great deal. They are inserts so you just pop out you mount and insert these into the gap. They do the job. Just a little vibration when your idle drops low. I just installed the front. Took 15 minutes. I had the Ingals damper but it was a joke as it is insanely noisy. I think I paid about 40 for the front mount inserts. Also the inserts for the tC do not require those zip ties because the insert is held in place by the motor mount bracket.
Old Apr 11, 2008 | 11:34 PM
KrazyAzianTC's Avatar
u have a diy by any chance? i just got some motor mounts and too lazy too guess how too do it LOL
Old Apr 11, 2008 | 11:39 PM
kocho333's Avatar
yea wat u mean just pop out the mount n switch it? i had the speed source motor mounts, front n rear...these look cheese compared.
BtW they for sale!!!
Old Apr 12, 2008 | 02:48 AM
Schuller's Avatar
Read the post slowly abd you will find the answers you seek.
Old Apr 12, 2008 | 02:16 PM
WendysOrBust's Avatar
So did you just install the fronts, or the sides, rear and tranny one as well? Did you notice a difference in wheel hop, heavy accelerating or heavy braking? I've been meaning to pick these up for a bit, wanting to hear some feedback thats all.
Old Apr 12, 2008 | 07:04 PM
Crippie's Avatar
1UP Crew
the fronts are cake
Old Apr 12, 2008 | 07:07 PM
RodC's Avatar
Well so far they have been called "cheese" and "cake". Can anyone provide some feedback that's actually meaningful?
Old Apr 12, 2008 | 07:10 PM
Crippie's Avatar
1UP Crew
lol.. can i say theyre strawberry? Strawberry cheese cake.. lol
theyre soo easy a caveman can do it! just look in your engine bay, right below the headers on the subframe that goes from the front of the car to the firewall its sitting right there, just disconnect crossbolt holding it from the right side i believe, get under the car, and remove a total of 4 bolts, (2 have a cover plate, then 2 underneath the plate) and use a jack to tilt the engine back... (if needed) the front mount should slide right out. then repeat the process backwards for the new one... can anyone check if ive missed something?
Old Apr 12, 2008 | 07:33 PM
Schuller's Avatar
I only installed the front. Hard to tell exactly how well they will perform around here because its still to cold outside for my Falken RT-615s to hook up properly. So far so good.
Old Apr 12, 2008 | 11:16 PM
Crippie's Avatar
1UP Crew
wait till you work the rears... lol
Old Apr 12, 2008 | 11:32 PM
SoFloTC's Avatar
how bad is the vibration ? is it noisy to?
Old Apr 13, 2008 | 12:20 AM
Crippie's Avatar
1UP Crew
there is vibration, so if you like a comfortable ride, i wouldnt suggest mounts. if you want performance enhancement... its definately worth it. what kind of driver are you?
Old Apr 13, 2008 | 12:27 AM
SoFloTC's Avatar
well im puttingin my dezod s1 kit this weekend ... is there anyway just to beef up the stock mounts so theres not vibration?
Old Apr 13, 2008 | 12:28 AM
Crippie's Avatar
1UP Crew
torque damper... but that can only do soooo much. and some people have complained that its noisy
Old Apr 13, 2008 | 12:34 AM
SoFloTC's Avatar
ya i dont want that
Old Apr 13, 2008 | 12:40 AM
Crippie's Avatar
1UP Crew
the only vibration i get is at idle, and a bit more with the ac on at idle, but while your driving its not that bad. If youre going boost, its def a great mod... IMO
Old Apr 13, 2008 | 12:42 AM
SoFloTC's Avatar
hmm a local shop can install these? im unexperianced with motor mounts.
Old Apr 13, 2008 | 12:45 AM
Crippie's Avatar
1UP Crew
should be able to. id say if your handy, DIY... if not, let a pro do it. Front is Strawberry Cheese Cake.. lol, so you can do the front yourself. Have the do the rear
Old Apr 13, 2008 | 12:46 AM
SoFloTC's Avatar
and these will reduce wheel hop and what else performance wise.
Old Apr 13, 2008 | 12:50 AM
Crippie's Avatar
1UP Crew
shifts will be a bit smoother and wheel hop
