need some help on spring install.
well today was a bit of fun for me. i got the hotckis springs for my car. i had the front ones installed in under an hour with no problems. i go to do the rears and my POS spring compressor can't commpressor the spring enough for me to install the top mount.
what compressor are you guys using? this is a real PITA. i was on a roll and i had to reinstall the stock unit..
any advice????
on a side note, my car looks pretty cool with just the front dropped
any advice????
the back you won't be able to compress with a spring compressor. get the car up in the air like you would, jack up the a-arm then uncompress the spring, by using the impact gun on the top nut on the shock. then repeat in backwards order to put the new spring on. you can take the stock springs off with the spring compressor but it's still quicker for the rears to just use this method.
it's kinda hard to explain it..... you have the car up in the air like you would normally do, take out all the bolts holding the shock in place, even the top 3 in the trunk. jack up the rear arm quite a bit to compress the spring, undo the nut on the top of the shock. lower the arm back down and the spring will be uncompressed now. pull the whole shock out which will all be loose now. put the new spring back on the shock and do this whole process in reverse order to install the new spring.
any advice????
any advice????
wait how do u get the top nut on with this A arm method..i tried the spring compressor to put the hotchkis springs on but it wont compress enough..i got the stockers off but couldnt get the new springs on
goatbelly
Jul 12, 2015 10:13 AM
Naughtygoose
Jul 6, 2015 09:59 PM
