New Dezod X-Rated brake pads now here!!!!
Well, we have done some MAJOR home work and decided to display a new product to the market for those looking for some new found braking power. We have come out with our very own brake pads for the tC that are a cut above the Hawk HPS, and not only that we have rear pads too!! These are a Severe Duty pad that can handle DD, Auto-X and Drag. The price points will be quite attractive and we will have more info at the end of this month.
* High metal and carbon content for extreme heat and load conditions.
* Low resin content for long life and maximum fade resistance.
* Original equipment style hardware.
* Original equipment style noise dampening shims for quiet performance.
* Slotted and chamfered just like OE for smooth, quiet engagement.
* Operates best under severe conditions and possesses a higher heat range than most pads.
* Dual layered friction for maximum sheer strength under severe pressures.
Fattore di Frizione! Friction factor is the translation and meaning behind these wonderful pads. They have an excellent initial bite, but retain the street properties of OEM with quiet stopping, less dust and squeeling. Direct fit for your application with no modifications needed. The wide heat range on these pads make them ideal for the daily driven weekend track warrior.
Stop obscenely fast!
http://dezod.com/cat_brake_pads2.cfm
Originally Posted by kanundrum
How does it compare to Hawk HT-10?
Our pads offer the following properties:
Slotted and chambered just like OE for smooth, quiet engagement.
Operates best under severe conditions and possesses a higher heat range.
Originally Posted by kungpaosamuraiii
Ok so they have a broader heat range? How do they operate when not heated up to ideal heat range?
Originally Posted by draxcaliber
could they come in a package like the stoptech stage 2 upgrade? so far that is the most attractive package to me.
Originally Posted by paul_dezod
Originally Posted by 2fast4you
How do they compare to Axxis Ultimates?
