Powerslot big brake kit
Some of you guys may want to consider a big brake kit from us. It's a full big brake kit with 4 piston calipers which are properly sized. Our kit has a 328mm rotor. 12.9" is the conversion for you folks. 2 pc floating rotor. If you want to see if this big brake kit will fit you wheels, just check our wheel fitment template here. http://www.stoptech.com/wheelfitchar...55-2430-02.PDF
I should also point out something about those caliper extension kits. If you move the stock caliper out onto a larger rotor. You are in effect increasing brake torque. Good thing? Not necessarily. Remember the brake balance issue?? If brake torque is increased in the front, it should also be increased in the rear to keep balance. Stock cars come with almost perfect balance. If brake torque is increased on the front but not the rear, then stopping distances will in effect grow longer.
See this link for more details on brake balance
http://www.stoptech.com/whitepapers/...erformance.htm
Even if you were to add a rear caliper extension. How would you know if was expended the proper amount to maintain proper brake balance. We take our brakes and do real world testing with out kits on a runway. Here is an article about our testing procedures on one of our reseller's website. http://www.zeckhausen.com/testing_brakes.htm
If you guys want to get a stiffer pedal out of the car, get some stainless steel lines. After that you'd have to get a big brake kit to have a stiffer pedal. The stock slingle piston slider calipers will allow the pedal to move some. A larger stiffer caliper will give a better pedal feel among other things.
Guys, we have a Toyota. You can probably get an amazing brake setup from supra and retrofit it to your TC. they cost around $500 used for a lot of braking power and looks for such low price.
I am from the Lexus crowd and we have been doing this forever. I will most likely go that route and see what comes of it.
Brake balance is essential for proper braking. Maximum braking power occurs when all four tires are about to lockup. Brake balance is making sure that both tires will lock at the same time with weight transfer in mind. Say you amp up your brakes in the front. Huge rotors with 12 pistons, stickiest pads, etc etc. Leave the rear stock. I guarantee you that with everything else the same, that your stopping distances will grow longer. This is because the rear brakes are being underutilized. Just like in the scanned article posted earlier. That article was actually written by one of our consultants. Keep these things in mind when talking about brakes.
Another common misconception is that rotors will help in braking. The pads do most of the stopping. Rotors and all features equated with the rotors are meant for cooling. Larger rotors will help with heat capacity.
Now for calipers. Almost all cars these days come with single piston sliding calipers. Evo8, Sti, and 350z Track are exceptions. single piston slider pistons aren't the most efficient, however they are the least expensive to produce with decent performance. Opposed calipers, pistons on both sides of the rotor, are more efficient in braking. The calipers are also stiffer which provide better pedal feel. The # of pistons don't really matter. It's the size of the pistons that matter. This goes back to the brake balance issue. We test our piston sizing to fine the correct one for the best brake balance.
Most big brake kits will come with a two piece floating rotor set up with aluminum hats. The floating rotors allow the iron part to expand and contract without warping the center hat. This is also a barrier which keeps the heat from your bearings. Two piece rotors also lighten overall weight of rotors.
There is so much information to go through. I can't nearly put enough in one post. Please see our technical section. It goes through almost anything and everything you would need to know about brakes.
http://www.stoptech.com/technical/
Also be sure to look through the FAQ section. http://www.stoptech.com/faq/
I'm absolutely sure that it will answer some of the questions that some of you have about brakes.
I was quoted $79 each X 2=$160 Front only. Add Hawk brake pads which are either free or not depends on what promo is going on. They fit 17plus size wheels. I had Power Slot Rotors on my Quad Cab Ram w/ 20's and it made a hell of difference. Paint the calibers, run Hawk pads, Power Slot rotors and new steel lines and walla. Big Brake for a small budget. Save dollars buy more stuff!!
Rebuild costs are higher
Thank you guys for the compliments. I figure why not try to edcuate an entire forum while it is in it's infacy states rather than join up later when people have learned myths instead.
Is a re-build something that you have to do if you just drive spirited? I dont do any track/or street racing, but I do cruise around pretty fast, and on occassion have to stop prety fast. How long do you think before I would need a rebuild?
I have been working with Toyotas and Lexi for over 7 years now and I know that most of them share similar brakes. Supra retrofit had improved braking on every single 2-piston Lexus application we put it on (always was a direct bolton). I am here to share some expirence and future plans. It is contributing and sharing knowledge for the good of the community.
But hey I can always jump and be a sidekick to any vendor of this forum; I am just not sure how much use that would be.
I'm nobodys sidekick, to be sure. I don't know that guy from Adam, but he knows his brakes, as opposed to the many that have no clue. I personally would never need or want this type of setup as the stock brakes are very good indeed. The only real advantages these setups offer is fade-resistance and better heat tolerance. If you are involved in some form of racing that requires repeated heavy braking, these might be the ticket. If you are some poseur who likes look, your wasting a wad of cash! FYI: Supra brakes won't fit on a TC . I learned years ago that racers need race parts and poseurs need Pep Boys!
I've had stoptechs on my audi... They have a bad case of rotors rust almost immediately... They are loud as a screeching woman when they are "street use" cold... People get the ultimate axxis pads and forget ... These are ment for more autcrossing then street use! I would of tried the street version axxis pads, but never needed to because the ultimates DO last long, but the trade off is a horrible squealing brake everytime you come to a stop light. Plus on that is that people know you are braking... My pops always said a squeaky brake is a good brake.. hmmm well....
If you are doing heavy breaking they are pretty nice though...
