question about wheel bearing
TOCC
ok my dad has an 07 tc, auto, its bone stock with roughly 66k miles on it, there is a growl at low speeds that turns into a roar, what are the chances that the rear wheel bearings are shot?
TOCC
nope, and holy crap on the price $300+ each, thats f'in nuts!
why do they go out so quickly? is there no TSB out on them? they've been growling (apprently according to him) since around 40k miles
Originally Posted by Ace83
300 plus? i replaced my front and the wheel bearing is only like 32 at the dealership..
If the wheel bearing doesn't get replaced then it can eventually seize up and F up a lot more parts costing you more in the end.
if you take hard turns to the left or right, you can usually isolate which wheel bearing it is when the weight of the vehicle is transferred. but yeah, that will suck if it's both rear.
tein coil overs
energy suspension poly busings
hotchkins front and rear sway bars stifff in the rear medium up front
front and rear endlinks
I used to live in florence oregon and the road looked like this.
http://maps.google.com/
and ya it ate up my wheel bearings.
tein coil overs
The rears are self contained units with the lugs already part of the hub/bearing. No need to press anything in with the rears, it's really an easy swap for the rears. The fronts require taking apart the front suspension (steering knuckle, brakes, ball joint, etc) to have the steering knuckle on a press to press out the old bearing and press in the new one. Hope that helps
Oh and after it's put back together the alignment has to be checked since the camber is most likely out. Only on the front procedure not the rears.
Originally Posted by asthmatic
As tires get older/balder, do they make more noise? I am in need of new tires. I'd feel better buying new tires instead of bearings.
