question from a newbie
Old Aug 18, 2005 | 06:56 AM
scionish's Avatar
Default question from a newbie
well, i was planning to install TRD shocks & lowering springs, and hotchkis sway bar set but here's the problem i ran into... the new house that i just baught has about 5inch drop from the driveway to the road... and i was thinking about just not installing the lowering springs whats so ever... and here's the question... would my install be no good w/o the lowering springs? if you have any suggestions, please let me know
Old Aug 18, 2005 | 08:29 AM
sciontc_mich's Avatar
well if the shocks are tuned to work with the lowering springs, then yeah you'd have a problem.. if the trd shocks are just to be used for a more "sporty" feel on any spring combo (stock or other) then you'd be okay.. wish i knew if they were for use in conjunction with the lowering springs.. your dealer might be able to tell ya, like the parts guy..
just what i could help with
Old Aug 18, 2005 | 01:56 PM
Fm_Tc_In_Ma's Avatar
Default Re: question from a newbie
Do you own the car yet? if so, what sort of clearance are you getting with the stock shocks and springs?
Old Aug 18, 2005 | 02:35 PM
ack154's Avatar
Moved to CC...
Old Aug 18, 2005 | 02:44 PM
GoSwim's Avatar
^^^^What he said.
You still might be able to clear it even with the TRD lowering springs.
Old Aug 18, 2005 | 03:42 PM
scionish's Avatar
how low does TRD ones make???
Old Aug 18, 2005 | 03:52 PM
I believe the trd springs lower your car about 1.2" - 1.5".
If you arent hitting bottom now, you should be fine with your driveway, just dont approach it straight on if you can. Try to angle your entry onto your driveway and you should be fine.
Old Aug 18, 2005 | 04:02 PM
GoSwim's Avatar
1.25" drop in the front and rear, with a 18% spring rate increase in the front and a 26% increase in the rear.
Old Aug 18, 2005 | 04:12 PM
05-RS1's Avatar
after the springs settle it tends to be lower an additional 1/8-1/4 of an inch
bootlgr
Jan 26, 2016 01:22 AM
jairolla_89
Apr 2, 2015 09:41 PM
Scionxa180
Mar 13, 2015 04:39 AM
tC6M
Nov 26, 2014 06:44 PM
xBassist
9
Jan 21, 2004 07:34 PM
