Rear Sway Bar Question...
This probably already been disscussed I tried "search'in"...but couldnt find what I wanted to know....so..Heres my question:
When installing a Rear Sway Bar..what kind of adjusting do you need??...I saw some post saying that you need to adjust it to the right setting in order to take the full advantage of the sway bar...is this correct?????
Or is it better to get it Professionally installed cuz they know what they are doing??
Thanks!!!!!
Thanks!!!!!
It's not any real form of adjusting that would require a special knowledge- there are simply two to three different holes (dependant on the bar) for the end link to mount to, for three different levels ranging from "street" to "track." I've got the Progress bar and it's set to 'track,' which means that it's on the innermost holes. The farther out, the less aggressive and less noticable.
I dunno does the Rear Sway Bar actually make an actual improvement??????
I been read'in some threads on here and other people beg to differe about getting a rear sway bar etc....SO...just seeing if its worth it etc...etc...before spending MORE money I dont have into car parts!!...
Checkout my Cardomain page:
http://www.cardomain.com/ride/2368924
I drove around with the Hotchkis rear only bar on soft settign for a while (even tracked it) and it felt great. The car stays flatter under cornering with no tendency to oversteer,but i was on Falken Azinis RT-615 tires. Im selling the rear bar only if you are interested...check my sig.
Originally Posted by AZPtC
Originally Posted by R2D2
Question: How much does one torque the rear swaybar (brand = TRD) ?
Just to be sure, can I get confirmation from someone?
Originally Posted by amanda776
How does the TRD sway bar compare to the other brands? I want to go with all TRD parts but I haven't heard much about TRD sway bars.
I personally just got a Progress rear sway finally, but have yet to put it in. So i can't attest to how it is yet. I was considering Hotchkis also but since they only sell the rear sway bar packaged with the front and i only wanted a rear, i went with Progress to save money.
But i can't wait to put in my Progress sway bar!!..perhaps later today......
Hey guys, I'm not a racer and i don't go auto-x-ing, just a daily driver and what i wanna know is, should i get just the rear sway bar or should i get both front and rear? some people say rear is enuff but would it really be beneficial to get both ? can you REALLY feel the difference with or without the front sway?
The front bar only comes with the Hotchkis sway kit. Hotchkis gives you bars that are over 100% stiffer than stock so yes, you will REALLY feel the difference. Is it necessary? If you're only daily driving, the TRD bar, coupled with a lowering set, is plenty.
Personally, I don't believe front swaybars are needed even for the more aggresive auto-x'ers (as i matter of fact I've heard it can actually hurt performance which translates into massive oversteer).
Hotchkis is the stiffest bar (27mm rear; 24mm front) on the market for our tCs (@ this moment), but i've also heard the front bar has/is encountering issues (i.e. rubbing, brackets, etc...) for "some" people.
Progress comes with links & bushings which I must say is something I'd love to have, however its not as thick as hotchkis' (progress = 22mm), but do share the same 3 hole setup.
And finally there's TRD which I myself have. It shares the same diameter with progress (@ 22mm) and also includes bushings, but doesn't have endlinks and that "extra" hole like progress'. Surprisingly, it is the lowest priced out of the three, and offers the least amount of hassle.
To me it seems Hotchkis has compatibility issues, but makes the better bar. Progress has an decent bar but comes with excellent goodies making it even better. And finally TRD, which in essence is the bare bones edition.... I honestly like my sway bar to the point that I think it should be standard on all tCs. So, until somebody comes out with a 27mm+ sway that's free of drama and includes the same goodies as progress, I'll be content with my TRD.
