Rear Sway Bar - TRD vs Progress
Old Jan 17, 2010 | 02:56 PM
TooCool_07's Avatar
Default Rear Sway Bar - TRD vs Progress
so im looking to get sway bars and was wondering which one i should get. i wanna get either TRD or Progress because i dont wanna deal with the hassle of installing the front sway bars.
but...
looking at the info of the TRD vs Progress:
both sways bars cost about the same. little under $200 shipped.
TRD
22mm thick *edit*
2 way adjustable
uses stock endlink
Progress
22mm thick
3 way adjustable
new adjustable endlink
stock
21mm manual / 22 automatic
non adjustable
stock endlink
correct the info if its wrong. just going off my head from what ive been reading the last hour or so.
*i figure the TRD is better because its thicker, right?**edit: (WRONG! both the TRD and Progress bars are the same thickness at 22mm) but im wondering if i would need to buy aftermarket endlinks to use the sway bar correctly? (bushing/boots on endlinks misaligned due to 2 different settings?) anyone care to share info/exp on this?
then theres the Progress sway bars. around the same thickness as stock but better much beefier material i would guess... some said it was two times heavier than stock. Progress has one more setting than the TRD and comes with adjustable endlinks that will keep the boots straight when adjusting the settings.
anyone with these bars care to back the bars they have on their cars so i can finalize my choice...
FINAL DECISION AND REASON:
Similarities:
both sway bars are the same size at 22mm (thanks pinoyFMtC for comfirming) and both cost around the same at a little under $200 (depending where you buy from).
Differences:
Progress sway bar has 3 different setting compared to the TRD which only has 2. Progress bar come with adjustable beefier endlinks compared to TRD which uses the stock endlinks.
Final decision: Progress Sway Bar.
thanks for everyones input on these sway bars. this is just my final decision base on what i need the sway bars for. someone else might have different reasons for choosing TRD.
Old Jan 17, 2010 | 05:18 PM
Kanchi's Avatar
I got the TRD, no complaints here, there is a few around with the Progress, hopefully they will chime in.
What are you going after with the sway bar/ what is the desired result? Are you autox or daily/spirited driving.
Old Jan 17, 2010 | 05:57 PM
scionic128's Avatar
i agree with kanchi, what your looking to get out of it will help you better deicide what sway to choose. i have the TRD and its on the street setting. never had it on the street performance setting but i have nothing but good things to say about the TRD one.
Old Jan 17, 2010 | 06:13 PM
huslindan's Avatar
got the progress's cuz i felt it was a better deal with the endlinks and 3 settings have it on the stiffest best mod i got even better then the lowering springs. got it for a good price though got it when it was only like 160 at p tuning like a year ago.
id go with progress over trd you'll never second guess yourself
Old Jan 17, 2010 | 06:29 PM
Rydrdg's Avatar
wow so the progress come with endlinks, I guess other sway bar does not because when you use the stock endlink it the bolts bend...
Old Jan 17, 2010 | 06:31 PM
DJ08tC's Avatar
yea progress comes with beefier endlinks and also has one more adjustment hole. I however went TRD and love it.
Old Jan 17, 2010 | 07:22 PM
TooCool_07's Avatar
my tc is mainly just street driven but i was looking into light autocrossing. just wanna join in on the fun when my buddies go autocrossing. currently just have tein htech which helps with avoiding dips, bumps, and stuff like that. im not looking into doing any hardcore autocrossing or i wouldve went with coilovers and hotchicks sway bars.
i just wanna see how other people feel about their setups and if ill have issues with the endlinks with the TRD sway bar.
if there is no issues with the endlinks with TRD ill go with that. but if people feel that the endlinks bug them enough that they feel they need to buy adjustable endlinks then ill go with Progress. (if the endlinks are even a issue) TRDs 25mm thickness is sold on me but im not too sure on the endlinks.
Old Jan 17, 2010 | 07:24 PM
DJ08tC's Avatar
had my trd for over a year and have had no problems with my endlinks.
Old Jan 17, 2010 | 08:12 PM
AcidDrop's Avatar
i've had the trd rear sway for about 2 years and haven't had any problems with the rear endlinks bending, before installing it i put some energy suspension bushings but i'm probably sure it didn't really make oit any stiffer. i've heard that the progress is really good as well but if you do decide to get that one, then don't over do it with stiffing it up...
Old Jan 17, 2010 | 10:05 PM
GQQSE13's Avatar
i've had the trd rear sway for about a year and no problems
Old Jan 18, 2010 | 03:14 AM
pinoyFMtC's Avatar
I thought both the TRD and the Progress were both 22mm? I could be wrong.
Anyway, I've had the TRD on my car before and currently have the Progress one. I like the Progress more. I never pushed the TRD sway in autocross, but the Progress one is amazing in autocross, car is much more neutral (set to the stiffest setting). Killed body roll in the rear. On the street, even in non-aggressive driving I can feel the Progress one more than I could the TRD one. I got the Progress for around $175 on CorSport.
Edit:
Confirmed the TRD sway is 22mm just as the Progress is. The thickest rear-only bar is the H&R one at 24mm.
Page 2 shows the TRD bar is 22mm:
https://www.scionlife.com/forums/sho...ickness&page=2
H&R review also confirms TRD bar is 22mm:
https://www.scionlife.com/forums/sho...+bar+thickness
Old Jan 18, 2010 | 05:58 AM
ScionSnowman's Avatar
Well I'm glad this thread was around. I've been deciding between these two and I like the Progress more. Ik its pointless to have it just looks sweet but I wish it came with the matching tie bar. My buddies RSX has a progress bar and it came with the tie bar. Looks badass
Old Jan 19, 2010 | 01:56 PM
TooCool_07's Avatar
well, it looks like Progress then. they both cost the same and are the same thickness but Progress has one more setting and adjustable endlinks.
Edit:
thanks for correcting. i edited the top too.
Old Jan 19, 2010 | 02:06 PM
captainlaziness's Avatar
I love my TRD sway. Four years and no issues.
Old Jan 19, 2010 | 04:06 PM
paul_dezod's Avatar
Scionetics
KAD
but...
TRD
22mm thick *edit*
2 way adjustable
uses stock endlink
Progress
22mm thick
3 way adjustable
stock
non adjustable
stock endlink
Similarities:
Differences:
You've made a good decision. We love the Progress bar. Hell I even have one on my wife's DD tC. LOL
http://www.dezod.com/pd_progress_rear_sway_barscion.cfm
Old Jan 19, 2010 | 07:53 PM
TooCool_07's Avatar
i bet ill love it too, but for around the same price the Progress give you more adjustability.
Old Jan 19, 2010 | 11:26 PM
pinoyFMtC's Avatar
No prob. Good choice with the Progress you're gonna love it. Just make sure the endlinks are the same length when installing.
Optimal endlink install, some good info in this thread:
https://www.scionlife.com/forums/sho...d.php?t=130228
Old Jan 20, 2010 | 03:40 AM
Eh, I suppose. But I'm not one to tinker with it once it's installed. The endlinks are a nice bonus though.
Old Jan 20, 2010 | 06:57 AM
Coolwaterz's Avatar
i got progress and its very good. i have it at the stiffest setting and notice a huge difference in corners. but going to go softer setting since its not practical for DD.
Old Jan 20, 2010 | 04:18 PM
pinoyFMtC's Avatar
How is it not practical? I DD with mine on the stiffest setting, and it doesn't affect driveability or comfort at all. Just better handling.
