rotor?/Pad? noise
Old Mar 12, 2009 | 03:44 AM
ilikepotatoes's Avatar
Default rotor?/Pad? noise
I was driving today and had the windows open and music off and when i come down to a real low speed about to stop, there is this friction sound, kinda like a pulsating hissing sound, it is very low and barely noticeable and can only notice it when its really quite out, and when i let off the brakes and just let the car roll to a stop. i got the front pads and rotrs down but not my back ones, got about 35K miles on it. maybe something is stuck in between the pad and rotors? like a small pebal or salt from the winter?
Old Mar 12, 2009 | 12:15 PM
ack154's Avatar
Could be the wear indicator on your pads rubbing the rotor. Are your pads low? Ever been changed?
Old Mar 13, 2009 | 02:20 AM
sonofabeoitch's Avatar
sounds like something i had/ still have. it is a problem with the rotors. i have a little honing piece for rotors, gave it a good none directional polish on both sides. the noise went away for a while. people say its the glazing, i don't know what to think. the rubbing grinding is not because the pad is low, i just switched to the hawk HPS pads and they still rub/grind. i can also hear it clearly when im going down a parking garage ramp. the uplsating might mean the rotor is at the beginning stages of warping, i could be wrong.
Old Mar 13, 2009 | 02:23 AM
diego_demarco1025's Avatar
yea when i start braking slowly from minimum speed i hear noise coming from my front left side, but i got my brakes changed like 5 months ago so i dont think its that, so idk what it is but i hate it
Old Mar 13, 2009 | 02:31 AM
Mong1126's Avatar
aftermarket brake pads FTL! n no is not ur rear pads(checked my rear at 50k n theres like 90% left LOL) you may need new pads for the front.. check em n if u need em, just replace it with OEM pads from the dealer(will run u about $60 for the fronts)
Old Mar 13, 2009 | 02:55 AM
they were rubbing/grinding more with the OEM pads
Old Mar 13, 2009 | 07:51 AM
Mong1126's Avatar
iono.. but when I had my hawk ceramic pads, it was loud n very dusty. went back to oem, quiet n no dust, whats so ever.
Old Mar 13, 2009 | 07:58 AM
hybridsolidr's Avatar
I have this issue as well with stock pads. It is only a slight rubbing noise that is dependent on speed and the level of brake being applied. I will have my car on a lift here soon and I will be taking a hard look at it.
dougcbx
Oct 23, 2015 11:42 PM
kb1sxv
Oct 21, 2015 05:00 PM
Klashan
Sep 24, 2015 12:39 PM
Andreas24
Sep 15, 2015 02:10 PM
mcnick0495
Scion tC 2G ICE & Interior
Sep 8, 2015 02:58 PM
