Shaking at 65+
Hey there. I'm running Tein Basic coilovers on 19's with 101k miles. Yesterday I replaced my pads and rotors on my tC. Now when I'm doing 65 or above my steering wheel and car shakes like crazy. Anything below that my car is fine! Before I changed rotors there was a slight shake but nothing like now! I'm heading out of state in a couple of weeks and I deffinately wouldn't take my car driving like it is now. Any ideas??
Harbor Freight has a nice run-out gauge and holder (to keep in place) for like $20-25 total. A steal compared to how much these are elsewhere.
If you're wondering why it's vibrating is because the rotor is a rotating mass, when you're moving it's spinning just like the tire is. So you can easily mistake a tire balance issue for a rotor run-out imbalance.
i have the exact same problem except the steering wheel shakes violently above 75. im still trying to figure out what is causing it as I recently only switched back to my stock midpipe and bought a used tire for the blow out i had on my front driver side wheel.
I talked to the people at the parts store and they said sometimes the rotors will come in and be off balance. They are going to trade me rotors and see of that fixes my problem. The weights on my wheels are still there so I know that's not the problem. Would tires almost at the wear marks make a difference??
and yeah i didn't think it was your wheels either, you didn't have this BEFORE you put the new rotors on. Tires at the wear marks if worn evenly shouldn't cause vibration. but you should replace them to be safe on the road.
like i was saying you only had this vibration AFTER you put the new rotors on. Only makes logical sense that's the issue.
What brand of rotors are these that you purchased?
i have the same problem, but don't know what socket to use to tighten the rotor...i was thinking a 23mm deep well, or a 22mm deep well, but im not sure, because my socket set only goes up to 21mm.
http://www.harborfreight.com/1-inch-...cator-623.html
and the base to attach it is here
http://www.harborfreight.com/multipo...ment-5645.html
It's been a while since I've been able to get back on here. I got a different set of rotors and it helped a little but there was still some shaking. I took my car to a tire shop where they found my wheels were slightly out of balance. No more shaking for me!!
Wheel balance, alignment (unlikely) ... It cannot be brakes because you're not touching the brakes. It will only shake (warped rotors) if you step on the brakes...
I would say steering bushings... Probably needs to be replaced. Check the bushings, racks, and what not...
my mr2 shook at 50-60mph ... anything over and below that it would stop. My bushings were asking to be replaced.
Klashan
Sep 24, 2015 12:39 PM
