So I finally took my car in for an alignment
Old Mar 23, 2009 | 11:59 PM
Vince2133's Avatar
Default So I finally took my car in for an alignment
So when I bought my car at 40k it was going off to the right side of the road, not extremely...but it just tilts to the right slowly.
So the guy at Allen's said my right lower controller arm is bend..so my right wheel was pushed back by a little compare to the left, but you just can't see the bend on the controller arm (what he said)
anyone had problem like this? I found the part for $50-100 buck..I mean for once I'd actually like a car that'd drive straight.
So he just aligned it to the best he can without getting the tires worned out..
Old Mar 24, 2009 | 12:13 AM
ack154's Avatar
He said it's bent but you can't see the bent part? WTH?
Old Mar 24, 2009 | 12:16 AM
Vince2133's Avatar
Well the controller arm is pretty big and thick
it could be bend by where the bolt is at but its hard to tell.
Old Mar 24, 2009 | 08:53 PM
xdejablu3x's Avatar
my friend works at the dealer and tells me that all new cars have a slight tilt to the right when driving straight so you drive off the road if you fall asleep instead into oncoming traffic. plus it could be the crown of the road to where its tilted so water can drain when its raining.
Old Mar 24, 2009 | 09:14 PM
t_dub's Avatar
That sounds pretty strange- bent enough to throw the car out of alignment, but not enough to see the bend in the arm?
Did he say if he maxed out the adjustments on the tie rods?
Old Mar 24, 2009 | 09:41 PM
Vince2133's Avatar
I dont know, I tossed away the print out for it
my steering wheel is like slightly turned most of the time while driving straight, like slightly slight turned to the right a little bit.
but whatever...lol
Old Mar 24, 2009 | 09:59 PM
t_dub's Avatar
The alignment tech didn't do his job if your steering wheel isn't centered when driving straight.
It's your car though, sounds like it doesn't bother you much.
Old Mar 24, 2009 | 10:02 PM
Vince2133's Avatar
Imma find me some trd springs..and will have to go back for an alignment then..so I'll just get it take care of then..another 60 buck..damn it..
Old Mar 25, 2009 | 04:58 PM
RA042726's Avatar
MN Scions
I think i have the same problem. A while back while there was snow on the ground, lets just say i had way too much fun with a curb. popped my front right tire and had a new one put on blah blah blah. so then i go to firestone to get it re-aligned, and he said there was something bent but he couldn't really tell what it was. my camber was off, I dunno. He suggested getting a new setup from the junkyard cause the dealers haven't come out with a replacement yet, but he sounded kinda retarded so i left. He said its just gunna wear that tire out faster. Put on lowering sorings yesterday and was just in teh shop this morning to allign it and they said the same thing.
dont think any of that helps huh?
sorry
Old Mar 25, 2009 | 07:23 PM
sciontc_mich's Avatar
ATTENTION.. you can read a bent lower control arm by the CASTER alignment reading number. That will tell you if it is truly bent or not.
Old Sep 28, 2009 | 11:43 PM
spooled50trim's Avatar
Yep, just had mine in for an alignment. It must have been in a minor accident before I owned it but the lower control arm is bent just ever so slightly. Tore my front right tire to the damn metal spikes. Wonder if its under warranty at toyota.
Old Sep 29, 2009 | 01:00 AM
^^ probably not, they'll just say that you hit something and that will be that.
kleecker
Jan 2, 2015 08:09 PM
sensez
34
Nov 24, 2004 12:30 AM
DjFrOsT
Nov 14, 2003 05:26 AM
tC_Normo
Oct 22, 2003 07:20 PM
Besk_one
Oct 16, 2003 07:45 PM
