spring installation
I think i'm going to purchase a set of Hotchkis springs pretty soon and keep it on stock shocks for now, but i was wondering how much i should expect my local shop to charge me for installation. I've seen around 150 and thats without allignment, is this reasonable? I would do it myself, but i lack the tools and time. And for anybody commenting about the hotchkis springs, please do! thx
150 is just right.... without alignment....
A shop will quote 2 hours labor for springs, so this is about right....
I'd do it for 50.
Anyways.... Hotchkis springs have a good rep... I'm sure you'll like 'em...
I'd do it for 50.
You need air tools,a spring compressor (Rentable from Autozone), a large torque wrench, and a breakbar... There are many how-to's online that can step you right through... I did my first one in about 3 1/2 hours....
But... for the work... It's worth about 150 imho.
Yes, it is the tires (Wheels) that get aligned....
With anything lower than TRD springs, your camber, castor, toe and other "Tweaks" to the suspension can get affected, so you need to have them adjusted.... otherwise, your tires may ride poorly and effect tire wear negatively...
If you want to learn more... check out this little guide...
http://www.familycar.com/alignment.htm
thanks for the link
it really helped.
"On many front-wheel-drive vehicles, camber is not adjustable. If the camber is out on these cars, it indicates that something is worn or bent, possibly from an accident and must be repaired or replaced."
so does that mean the camber isnt adjustable for the front for the tC's and that is why we only have rear end camber links out on the market for the tC?
it really helped."On many front-wheel-drive vehicles, camber is not adjustable. If the camber is out on these cars, it indicates that something is worn or bent, possibly from an accident and must be repaired or replaced."
Its reccomended but not required. With a conservative drop like th e TRDs, the changes arent as dramatic so it isnt as important. Ideally you should have the car aligned after installing springs but its not a problem if you dont.
scionlife
10
Mar 1, 2016 09:14 PM
bBOXD
28
Dec 7, 2003 07:08 PM
randode
18
Nov 19, 2003 03:37 PM
randode
Sep 30, 2003 10:50 PM
