Strut Help
i did a spring and strut swap with a guy. his springs had about 30k miles on them and i was wondering if i still need to get an alignment because the springs were settled on his car first and then transfered to mine.
Well you don't get an alignment because the springs settle, you get it because they lower the car and it messes up the suspension geometry and can cause excessive wear. I would do it just to be safe.
yeah it felt like there was rattling at the front left and right strut areas especially at lower speed going over speed bumps and dips.
so my car is at the dealership for an oil change and alignment so hopefully that will clear things up
thanks for the help buddy
-kevin
-kevin
if theres rattling, check all the bolts. thats usually not an alignment issue. but rest assured after your alignment, your tires will not wear out super quick.
sorry i shouldnt have said rattling
its more like a "clunk clunk" sound when i go over speed bumps and dips
and i re-tightened the strut bolts yesterday
welp i just got my tc back from the alignment and it didnt fix anything with the clunking sound in the front 2 struts
ill pay someone $50 to fix this problem haha
mine does the same thing from the back. I believe it's a rubber part not sitting right above the spring. I can see it, but it's such a PITA to get it out to fix it. I gotta get aligned soon, it's been over two weeks since i got lowered
kb1sxv
Oct 21, 2015 05:00 PM
Scionxa180
Aug 30, 2015 04:12 PM
Scionxa180
Aug 30, 2015 03:50 PM
goatbelly
Jul 12, 2015 10:13 AM
