Suggestions on brake pads
The Axxis pads are ok for normal to quicker driving, they are a ceramic pad and carry a lower friction coefficient than semi-metalic pads. They are better for the everyday driver because they are quiet and produce very little brake dust. They also work as an insulator making them not good heavy duty use.
If you want a better OEM pad but something that won't be loud, dusty or harsh on your rotors get the Hawk HPS. If you want the best street pad and don't care about noise, dust, or rotor wear buy the Hawk Hp pluses. Porterfield makes excellent street/track pads aswell. They also offer a very good rear pad, the RA-S.
I've currently ran 6 Auto X events on my Hawk HPS's, but I plan on upgrading to the HP pluses in the front, and the RA-S's in the rear with SS lines and some high temp fluid.
Let's start by saying that ceramic brake pads have a place in the automotive industry. They were designed to be a low-dust, noise-free brake pad. They came into popularity after the discontinued use of asbestos-based brake pads. At that time, semi-metallic pads exhibited problems with higher noise and dust levels.
That being said, I can tell you that Ceramic Brake Pads were NEVER designed to be a performance brake pad! Some companies have done a terrific job marketing their higher-priced, ceramic pads to the consumer as a performance pad. Ceramic brake pads typically have lower friction coefficients, and act as an insulator - raising rotor temperatures in cast-iron disc systems. When you have a vehicle that has persistent braking problems- the last thing you want to do is install components that have a LOWER friction coefficient and that RAISE effective operating temperatures! See our section on how this can cause ' Warped Rotors "
Premium-grade semi-metallic or hybrid pads are more effective for handling elevated temperatures and dissipating heat away from rotors. Most, if not all, semi-metallic pads have a degree of ceramic content ALREADY IN the brake pad.
Premium-grade, semi-metallic pads can offer LOW-DUST, NOISE-FREE Performance without sacrificing stopping power and increasing rotor temperatures!
Most organizations with fleet vehicles and other extreme-service applications already know what we're telling you: High-quality semi-metallic pads offer the best combination of stopping-power and extended-wear of any brake pad type on the marketplace today
endless has some of the best brake pads out there, maybe this can widen your options
http://endlessusa.com/category.php?c=brakepad
to add to the discussion..
Porterfield R4-S brake pads. Carbon/kevlar compound. Brakes as well at -10 as it does at 100 degrees (ambient temps). good stuff, you'll love it.
Plus for street use I've seen them last about 50,000 miles.
TotalChaos
Apr 7, 2015 09:02 PM
kdanie
10
Jan 25, 2004 07:08 PM
