Sway bars installation.... Failed
Old Aug 8, 2005 | 03:29 PM
B1uEsC1uEs's Avatar
Default Sway bars installation.... Failed
about 3 days ago, i went over to my friend's house to install the hotchkis sway bars. we had a 85 ft. lbs of torqe wrench ready (i think it was 85) and then we read the installation guide and it said we needed about 146 . then we went over his neighbor's house to borrow his torque wrench which can handle 160. it was huge compared to the other torque wrench. Even with a 160 ft. lbs of torqe, we still couldnt take out the bolts because they were hella torqued in. . Anyone know where i can get this installation for a good price? I dont want to go to the dealer because they overcharge.
Old Aug 8, 2005 | 03:41 PM
ack154's Avatar
You shouldn't need a torque wrench to remove the bolts... just to put the new ones on.
Old Aug 8, 2005 | 03:47 PM
Marshall's Avatar
I feel ya... I had the same problem. Those steering cradle bolts are tight as hell!
I bought an electric impact wrench at Wall Mart and it still wasn't strong enough. What I did was find a close local shop. I paid the guy a ten spot and he lifted the car and used his air impact wrench to just 'loosen' then retighten the 4 bolts enough to hold but allow me to untighten with a good wrench at home.
I had to drive for two days before I had a day off to work on the car, after it had a whole night to cool down. I will warn you, that during those two days I did notice that the steering wheel had a bit more 'play' and I was not comfortable driving it.
I helps a lot to leave the car overnight at the spot you will be installing your bars at. All that metal gets hot hot!
Good Luck, is well worth the mod.
Old Aug 8, 2005 | 04:14 PM
KrazyAzianTC's Avatar
you shouldnt use a torque wrench to remove the bolts if u do u will damage the torque wrench. what u need is a breaker bar that will help u "break" the bolts so that u can losen them with a ratchet
Old Aug 9, 2005 | 02:46 AM
Joe_Dezod's Avatar
Well said. And breaker bars don't cost that much. I can't say how many times it's come in handy with me.
Old Aug 9, 2005 | 02:53 AM
shinkuu's Avatar
agreed on the break bar part. are you in socal? i can get you a shop to do it if you are
Old Aug 9, 2005 | 02:54 AM
B1uEsC1uEs's Avatar
yes im in socal
Old Aug 9, 2005 | 03:41 AM
TimmyT's Avatar
Scion Society
Torque wrenches are for measuring torque when you tighten bolts... not for taking off bolts. I used a Pneumatic Impact wrench, and a good ol' breaker bar.
Old Aug 9, 2005 | 03:44 AM
mfbenson's Avatar
If you must you can slip a pipe over the end of the breaker bar. You might break parts, you might seriously injure yourself, or it might work just fine. But results are guaranteed! (I just can't say if it will be the results you want...)
Old Aug 9, 2005 | 04:38 AM
GoSwim's Avatar
Alright!, that's how we do things at Scionlife :D Just give it hell, and if it doesn't work keep extending it for more leverage.
Old Aug 9, 2005 | 06:36 AM
lvnurs9's Avatar
Thats funny..I installed the bar after we lowered it and we lowered it by hand...no power tools
Old Aug 9, 2005 | 01:57 PM
slammed's Avatar
ya, installed coilovers by hand...breaker bars and spring compressors. My Craftsman jack has a removable handle which doubles as a breaker bar.
Old Aug 9, 2005 | 02:26 PM
hayalex6's Avatar
Pfft breaker bar....I just use my guns.
Old Aug 10, 2005 | 02:21 AM
B1uEsC1uEs's Avatar
so where is the shop at?
Old Aug 10, 2005 | 02:29 AM
freeflowing's Avatar
damn a breaker bar will do but you still need the gunz to finish the job.
Old Aug 11, 2005 | 07:17 PM
shinkuu's Avatar
you got PM(s)
Old Aug 11, 2005 | 07:27 PM
B1uEsC1uEs's Avatar
you got PM(s)
i checked my inbox and no pm's sent.
Old Aug 11, 2005 | 08:37 PM
shinkuu's Avatar
hmm i sent it to someone else who asked the same thing. check again. =)
Old Aug 11, 2005 | 09:49 PM
B1uEsC1uEs's Avatar
thanks dude, ill let you know asap when im about to get the install.
Old Aug 12, 2005 | 04:18 PM
SupaWhiteTc's Avatar
Two Words, IMPACT WRENCH. It will remove almost any bolt. My sway was cake work took like 1/2 hour for the rear.
