TRD Lowering Springs
Does anyone know if after using the TRD Springs and getting the 1" drop if that throws the camber of the tires off at all??? Will the tires wear unevenly with the 1" drop. Please let me know if anyone knows??? thanks!!!
Anytime that you change the stock suspension set up you are going to change camber. The springs are shorter therefore your camber will be off. The real question is how much the camber will be off...is it enough to worry about or not...well that is kinda up to you. Yes your tires will wear out faster than if you had left the car alone but no I don't believe that the camber is off enough to be buying tires every two months. So the choice is up to you..whether or not to buy a camber kit. Just because something is from TRD doesn't mean squat...eiback manufactures them and they technically are for off road (racing) use anyways.
When you have them installed at a dealer they do an alignment. To me that says it should be done. But like PolyFM_TC said anytime you lower a car you're gonna change the camber. So I say get the alignment that way you're sure. I mean whats and alignment cost $60 bucks or so and whats a set of tires gonna run you $250+. You ca weigh the options.
The TRD Springs do not greatly change suspension alignment. I had my TRD Springs on my car for 13k miles, rotated them front to back once at 7k and they wore flat acrossed the tire patch area.
DJ_FroZone
25
May 30, 2019 07:17 PM
Scion0814
Scion xB 2nd-Gen Wheel & Tire
Feb 12, 2015 01:41 AM
