TRD Shock Issues.... HELP!
Old Apr 30, 2007 | 06:13 PM
StealthScion's Avatar
Originally Posted by josh_trdsparks
Originally Posted by StealthScion
i don't see any oil. but i think the ride height may be different between the two struts.
driver side appears to be half inch lower than passenger. Ie. i can easily fit index and middle finger in the wheel gap on pass side, barely to not at all (2 fingers) on the driver side.
Do you mean front and rear for just one corner? Who did the install?
no, the gap above the top of the tire.... driver side there is a .5" gap, pass side there is a 1-1.25" gap.
Old Apr 30, 2007 | 06:22 PM
trdsparks's Avatar
Ok lets try this another way. Is wheel gap in the rear even side to side? and is the passenger side even with the rears? Is the front driver side the only corner of the car that is lower?
Old Apr 30, 2007 | 09:05 PM
i give up. its not that hard to comprehend. i'll stick to trying to explain it to someone who actually has a tc.
Old Apr 30, 2007 | 09:13 PM
trdsparks's Avatar
**edit**
Old May 1, 2007 | 12:29 AM
ratmanpack's Avatar
hey stealthscion, i went through a bunch of suspension posts on scionlife before... i remember a lot of people saying that their drivers side was lower than their passenger side... so since so many were talking about it, i'm not sure if the height difference is really abnormal... some were saying it's because we always sit on the drivers side seat, whereas the passenger side is most of the time not occupied... mine is even right now, but then again i don't drive it much... and i just got my front end installed last week so not enough time...
josh, i'm not sure if that sounds right and if anybody ever came to your dealership asking about it...
as for the noise, sorry but i'm not much help
Old May 1, 2007 | 02:03 PM
There was an issue when the tC was first out with the rear struts not being installed properly. To be more specific the rear passenger side was not being tightened down all the way and cause the rest of the car to sit funny.
Before you come out here and get an attitude try answer the question that are asked.
there are no "rear struts". they're rear shocks. the fronts have struts. case in point.
Old May 1, 2007 | 02:07 PM
trdsparks's Avatar
**edit**
Old May 1, 2007 | 02:14 PM
trdsparks's Avatar
**edit**
Old May 1, 2007 | 02:34 PM
yes that is a strut. because the spring is housed between the two perches/mounting plates.
that is NOT what is on the rear of the tc. the rear of the tc just has shocks and springs. the bottom of the spring rests on the shock perch, the top of the spring makes direct contact with the chassic at the top mount of the shock tower.
struts are involved in steering as well. shocks just move up and down. (shouldn't u know this is u work at sparks?)
spring over shock = Coilover
Old May 1, 2007 | 02:37 PM
the trd set is FRONT STRUTS and REAR SHOCKS. go look at them. they aren't the same item for from and back. :D
Old May 1, 2007 | 02:55 PM
trdsparks's Avatar
I'm done. Good luck......
Old May 1, 2007 | 03:26 PM
thanks, u can go back to washing/detailing cars now....
Old May 1, 2007 | 05:17 PM
Spider13's Avatar
Locked due to straying waaaay off topic.
5N1PE5
Aug 3, 2015 11:25 AM
Subaru86
Jul 31, 2015 04:33 AM
Subaru86
Jul 31, 2015 04:00 AM
tribe
Jul 25, 2015 05:21 PM
goatbelly
Jul 12, 2015 10:13 AM
