TRD spring question
Well I don't mind the drop that much cause I'm aggressive and especially here in OC to me imo trd is ok. As long its less bouncy than the stock spring I think I'm ok with it..
Don't need to cut bump stop etc for trd spring right?
To me they're more bouncy than stock. Stock is soft and absorbs bumps so I didn't feel them as much, after TRD it bounces on everything. Now the TRDs do make the bouncing stop quicker than stock, so I guess maybe that's what you mean by "less bouncy"?
As for improved handling, yes, TRD is much better than stock for performance driving.
Originally Posted by SquallLHeart
the instructions for the trd spring install, I do think, tells you to cut the bumpstops
I haven't heard about cutting bump stop on TRD's..just Tein's....even so some people still didn't cut their bump stop on Teins..what exactly do the bump stop do lol
and ya I get what you mean by stiff* it makes it more of a tighter* ride so its not all soft and stuff
how many inches can you drop it with the trd springs? I'm looking into dropping mine cuz i got tired of the wheel gap. I'm thinking i wanna drop it maybe an inch and a half...is that possible with the trd's?
They are more "bouncy" than stock. But that's what you get when you switch to a higher rate (stiffer) spring.
And there's no need to cut bump stops when you use TRD springs. You'll never bottom out with those springs... If you use an aftermarket shock/strut with TRD springs then you should cut the bump stops, but if you're just using stock shock/struts then no.
