Unable to do allignment after spring install?!?!?! WTF?
Old Aug 20, 2005 | 08:19 PM
Tampa-tC's Avatar
Default Unable to do allignment after spring install?!?!?! WTF?
After I installed my S-techs I took the tC to the dealer to get an alignment in order to keep my tires for life. they said I cant get it done because of the drop and its all screwed up. I was ____sed, like wtf??? anybody else have this problem?
Old Aug 20, 2005 | 09:02 PM
Tomas's Avatar
Admin Emeritus
Second step of the procedure is to verify static height is within specs - if it is not, you can't do the next step until it is. (The odd way it is measured allows for different actual ride heights because of non-standard tire and wheel sizes. If the measurements are not correct (A minus B and D minus C) then the suspension geometry has been changed enough that using factory alignment numbers is meaningless.)
Here's what the factory manual says:
Maybe an independent shop would ignore that...a Scion or Toyota shop shouldn't.
scionlife
10
Mar 1, 2016 09:14 PM
ScionDP
Mar 1, 2015 10:57 PM
bBOXD
28
Dec 7, 2003 07:08 PM
randode
18
Nov 19, 2003 03:37 PM
randode
Sep 30, 2003 10:50 PM
