WHAT TEIN COILOVERS SHOULD I GET???
Old Sep 5, 2005 | 04:30 PM
krazykj03's Avatar
Default WHAT TEIN COILOVERS SHOULD I GET???
i am just wonderin what tein coilovers i should go wid? and how much do they range frum? cuz i think they got like 3 types and what are the differences between them? the SS-P, SS and the BASIC... thanks
Old Sep 6, 2005 | 12:26 AM
-Keith-'s Avatar
www.illusivemotorsports.com
It really depends on what you want them for... are you gonna race it or just for adjustabilty? You like a bit of camber in the front? How low do you want to go? you want somthing easy to install... Answer those questions and ill give u a answer
Old Sep 7, 2005 | 06:05 PM
shinkuu's Avatar
SS-P from 1150 to Basics for around 700
For the easiest installation and most adjustability, get the SS-P. You will also have the option for EDFC.
Old Sep 7, 2005 | 11:37 PM
B1uEsC1uEs's Avatar
does the EDFC adjust your car height while your in the car?
can you feel your car move up and down?
is EDFC worth it and why?
any requirements for EDFC?
Old Sep 7, 2005 | 11:59 PM
Male_Nurse's Avatar
I'd also like to know this information.
Old Sep 8, 2005 | 12:02 AM
R2D2's Avatar
Answer = https://www.scionlife.com/forums/vie...484&highlight=
Old Sep 8, 2005 | 12:43 AM
shinkuu's Avatar
I couldnt find the answers the his EDFC questions in that thread. Only found one instance of the word 'EDFC'.
EDFC does not adjust your car height in anyway. EDFC stands for Electronic Damping Force Controller. What it does is allow you to control your damping force while you're in the car.
I'm guessing ur assuming it controls ride height and u can feel ur car moving up and down so no. What you can feel is the difference from a soft dampening road and a stiff dampening force. Go to the track, make your suspension stiffer, drive around town, make it softer to absorb more of the road bumps.
This is up to you. It retails for $380. How lazy are u to change your dampening settings. You need a hex wrench to adjust. Front ones are easily accessible, rear ones will require you to disassemble the hatch area to get to the top of the coilovers. EDFC, u press a button and its done.
Only TEIN SS-P are compatible with EDFC. The upper pillow ball mount allows enough clearance for the EDFC to fit.
Old Sep 8, 2005 | 06:55 AM
dubledee's Avatar
only if u had money, go get tein HA or RA :D or FLEX. but the others are just jdm bling. overrated and overpriced
Old Sep 8, 2005 | 07:01 AM
AntwonePeterson's Avatar
Wait a while for the Buddy Clubs. They should be a little cheaper I think. Maybe around a grand.
Old Sep 8, 2005 | 01:01 PM
imsonofagun's Avatar
I ordered my TEIN SS-P with the EDFC from Keith at Illusive Motorsports. Good people to work with. Anyways, I figured I'd go with the SS-P since it's in a way easier to install because of the pillowball mount (don't need a coil compressor to take off the stock springs and shocks). I also figured why not replace everything at once (instead of springs, then eventually shocks). Only thing I have to figure out is how low of a drop I want.
As far as what you should get, figure out how much you're willing to spend, and what kind of adjustability you want. You'll be able to adjust the height on any one of them, but if you would like to adjust the damping rate, then the TEIN SS and SS-P are a good option. The EDFC isn't really worth it to most people (because they'd just rather leave things well alone once everything is set where they want and save the $325). I on the other hand like toys and gadgets, and have the money lol. I'm not too familiar with the other companies. TEIN has been around for a while, so I'm willing to put my trust in their products.
I also read an article somewhere (I think PAS Mag) that you can send your struts back to TEIN and they'll basically overhaul them (I'm sure for a fee) so you don't have to buy a whole new set, and I also read you can send them back so they can adjust the damping rate for more aggressive or less (revalve). Kinda cool.
Old Sep 8, 2005 | 01:40 PM
B1uEsC1uEs's Avatar
oh ok, thanks guys
greytc
Oct 26, 2015 07:53 PM
Darrenohooligan
Sep 26, 2015 07:21 AM
rmz489
Sep 16, 2015 08:19 PM
ScionDP
Sep 8, 2015 02:17 AM
