18'' wheels with 2 or 3 inch lip!
Old Apr 14, 2011 | 01:40 PM
TruWil's Avatar
Default 18'' wheels with 2 or 3 inch lip!
Just bought my Tc and want to throw some wheels on it. I want a mesh wheel with a 2 or 3 inch lip. I've been doing my research and now want to see pics of your rides to help me make a decision. If your rims have this type of lip, help me out and post your pics. I'm not ''locked'' in on a mesh wheel. God bless.
Old Apr 14, 2011 | 07:39 PM
kahsperr's Avatar
2006 tC?
Old Apr 14, 2011 | 07:47 PM
RS2_1823's Avatar
^^ check out the aggressive wheel thread.. there are plenty of deep lip wheels there. Some sites to check out would be wheeldude.com and raderwerks.com
Old Apr 14, 2011 | 08:35 PM
TruWil's Avatar
Yes, it's a 2006 Tc. Thanks for the info RS2 1823.
Old Apr 14, 2011 | 08:42 PM
Spoony's Avatar
What's your budget?
Old Apr 14, 2011 | 08:55 PM
Hayseed's Avatar
XXR 526 17x10. HUGE lip. Bam, done.
Old Apr 14, 2011 | 09:12 PM
TruWil's Avatar
I want to stay around $1,500 for the set.
Old Apr 14, 2011 | 09:34 PM
Spoony's Avatar
Like RS2_1823 said: Raderwerks, M-TEN80 S. Really "meshy", and slightly higher quality for a cast wheel.
I think scion_jon has them, or something similar. Sexy wheel.
Old Apr 14, 2011 | 09:52 PM
TruWil's Avatar
Thanks for the help, this is good stuff! Yall feel free to post pics!
Old Apr 14, 2011 | 11:41 PM
TruWil's Avatar
I'm thinking of about a 1.5'' drop, any idea how it will drive?
Old Apr 15, 2011 | 02:27 AM
mystik's Avatar
CinSity Scions
it will drive well with only a 1.5" drop. but running 3" lips would mean your wheels would have to be at least 9" wide or unless you somehow come across something with really low offsets. if your wheel is 9" wide, your offset would have to be around 25-30 for 3" lips...but then with only a 1.5" drop your wheels might stick out past your fender because you will have very little camber from your drop....just a few things to think about
Old Apr 15, 2011 | 12:13 PM
TruWil's Avatar
mystik, I just don't want to run into a situation where my rear wheels are "slanted" inward. I'm ok with them sticking out past the fender as long as it's minimal. Thanks for the info!
Old Apr 15, 2011 | 01:30 PM
Hayseed's Avatar
You're going to be looking for a wheel that has a very high offset then. Also, it shouldn't be too wide. Otherwise if it pokes and you're not goin to lower it enough and camber it then it'll be a perfect example of mexifail.
Old Apr 26, 2011 | 03:13 PM
TruWil's Avatar
What type of adjustments will I be forced to make (if any) if I try to put 19x8.5 linea corse lemans on my tc? 5x100/ +45/73
Old Apr 26, 2011 | 03:28 PM
GQQSE13's Avatar
tsw makes a set with a 2" mirrored lip that's mesh called the Snetterton
http://www.wheelfire.com/scontent/Wh...ption=Standard
Old Apr 27, 2011 | 06:07 AM
mystik's Avatar
CinSity Scions
if its +45 offset you will need to add some camber otherwise you wont clear the fender and your tire will hit it. the 73 is hub bore, thatll fit.
Old Apr 27, 2011 | 12:58 PM
TruWil's Avatar
Will I run into the same thing if I go with 18's. If so, what type of camber kit would be good to go with?
Old Apr 27, 2011 | 01:54 PM
mystik's Avatar
CinSity Scions
you wont need a camber kit, and yes you will run into the same issue with 18s...you shouldnt need to camber it too much, maybe -1 degree to -1.5 would be more than enough.
Old Apr 28, 2011 | 03:40 PM
TruWil's Avatar
Miro 279 18x8 , 35 offset. Good deal or bad idea?
Old Apr 28, 2011 | 04:23 PM
Hayseed's Avatar
If youre worried about rubbing, just go with a 17. The Miros are a great choice though.
