19's Axis on tC (MORE PICS) 8/20/06
Well i finally got my wheels. I will have them put on this saturday. I bought the axis pentas and they are 19's. (19X8.5 F) (19X9.5 R) TIRE SIZE F: 235/35ZR19 R: 265/30ZR19 . Now im afraid that they wont fit becuase i have lowered my car using trd lowering spring. Will they fit or not??? Thanks for the replys
finally installed
finally installed
I have 19x8.5 Axis with the TRD drop and ive had my share of issues...yes they will fit but you may have to do a few things. What size tire did you go with? 215's? they look kinda small.
F: 235/35ZR19
R: 265/30ZR19
Wheel Size:
F:19x8.5
R:19x9.5
I think 235 is the perfect size tire for the protection of the rim , I would only worry about the rear since your wider. I know there are a few ppl on here with the staggered set up and seem some have issues and some dont. But then again they may be running 18's and not 19's. I do think you can make it work though, like I was saying by rolling the rears a little bit.
Maybe ppl with the staggered set up will make a post and help you out a little more.
hope im not too late. im running 19x8.5 and 19x9.5. im on stechs which is a lil lower than the trds. my tires are 215/35/19 and 235/35/19. theyre a little stretched and they barely fit. they rub occasionally when i hit dips on the freeway. nothing serious tho. hopefully the TRD drop will make up for the bigger tires that you have. let me know how it goes! if it clears, i might look into 225s when i end up buying new front tires.
265 in the rear is too wide. althought it fits the rim width, it'll cause rubbing. you'll need narrower tires or roll the rear fenders. put some spring spacers between the coils to prevent the rears from rubbing/compressing.
also lets see some pics of these bad boys, nice wheel choice man
I havent forgotten about this thread. It just i currently do not have a digital camera. I have installed the wheels. And i do experience some rubbing when i make a hard turn. Other than that im happy with them. My tC looks hella of lot better...Pics will be coming sooon
