Is +45 offset too much???
I own a FM tC and I want to purchase the motegi Dp6 in hyper black 18x7.5 but im just concerned that with an offet of 45 its going to be sticking out way to far. Will i have to worry about rubbing? I also plan to but a TRD drop on it as well please advise.
45 offset is the same as stock so with a 7.5" wheel youre only looking at a few mm wider than stock. Im 17x8 +35 which is 23mm wider than stock per corner and Im still not even completely flush. You will be fine with those wheels.
a 51 mm offset will actually push the wheels inward by 6mm over stock. A higher number offset means the wheels will stick out less when the width is held constant. Wheel widths play a big role and make it hard to visualize, which is why I recommend this link to get a good idea of what changes you will see:
http://www.rims-n-tires.com/rt_specs.jsp
Originally Posted by Kilo6_one
what about 51? im thinking of switching to some prodrive pff7 and they only seem to come in the 51mm offset, they are 18x8
depending on tire width and how low the car is, you may rub against the springs.
i would not roll with Subaru offset wheels, unless you put some 15-20mm spacers on.
yeah, im just not sure about using spacers......i have never used them, they are already like 1800.00 a set for 18's i may just look at something else considering adding spacers for an addtional 300.00
Theres really no issue in running a quality hubcentric spacer other than the price. The nice thing about the H&R kits is that they include new wheel studs as well so you dont have to worry about having insufficient thread depth in your lugnuts.
my 18x7.5 +48mm offset wheels fit fine. The only problem that I have with them is that the center wheel stud on the fronts stick out too much and I cant fit my center cap over them. spacers would fix this though, but alas, im too cheap to do that :D
xBrelease08
Scion xB 2nd-Gen Wheel & Tire
12
Feb 29, 2016 05:39 AM
umnitza
Sep 1, 2015 08:06 PM
